Author Topic: REAR DISC BRAKES???  (Read 6092 times)
Offline 76_Scottsdale
  • I'd rather push my Chevy than drive a Ford
REAR DISC BRAKES???
« on: April 24, 2007, 08:25:46 pm »
Hi Ya'll,
I've noticed that many of the great pickup projects on here feature a rear disc brake conversion. I have a 1976 Chevy K20, and I'm going to put a rear disc brake conversion on it. First, I had a couple questions. What rotors/calipers can I use that will work on my 14 bolt rear end? And I was also wondering what you guys do for an emergency brake once your drums are gone, as I definitely want to keep an e-brake.
Thanks for any help.
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
True Dual 3" Flowmaster 40 Series Exhaust
Offline BILTUP
Re: REAR DISC BRAKES???
« Reply #1 on: April 24, 2007, 11:16:25 pm »
I used the rotors,caliper,pads,brake hose from the front of mine.  1980 3/4 ton.  Any 8 lugs off the front should work.  You can use cadillac rotors for the e-brake.
http://pirate4x4.com/tech/billavista/14b%20disc%20brakes/index.html
http://www.shakerbuilt.com/14_Bolt.html
http://www.pavementsucks.com/showcase/jkwbrackets.php
« Last Edit: April 24, 2007, 11:19:53 pm by BILTUP »
