Author Topic: A pillar; what's inside?  (Read 5212 times)
Offline Darth Goofius
« on: April 25, 2007, 08:33:25 pm »
I am working on getting adding cab markers to my Blazer.  Ideally, I would like to run the wire down inside the a pillar.  Has anyone done anything of the sort?  I would like the install to be as clean as possible.  My truck does not have any of the interior moulding strips on any of the pillars.  So, I really could not simply hide it there.  Is there an "best" way to run the wire inside the pillar?
1986 M1009
Re: A pillar; what's inside?
« Reply #1 on: April 25, 2007, 09:11:25 pm »
Not really a good way to do this on the blazer unless you can fish it through the visor hole somehow.
« Reply #2 on: April 26, 2007, 05:59:21 am »
Once you cut your holes for the lights, up under the dash you will see a hole you can fish a piece of mechanics wire up through, or down through from the top. I have done it both ways. Its a Pain in the rear, but if you want the wires hidden Thats the only way to run them, there is two layer of metal. Its been a while but if I remember correctly you need to be inside both of them.
