Author Topic: Brakes  (Read 6997 times)
Offline mikewb
Brakes
« on: May 01, 2007, 06:51:00 pm »
I got a problem dont know where this goes but im puttin it here. My back brakes dont work when i hit the brakes unless i pump the pedal a couple times first then ill feel then workin. anybody had this problem
Offline 75 C20
Re: Brakes
« Reply #1 on: May 01, 2007, 08:16:58 pm »
did you check your brake fluid level?
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Offline mikewb
Re: Brakes
« Reply #2 on: May 01, 2007, 08:23:53 pm »
Yes fluid levels fine. its been like this for a while. just trying to figure out what to do to make it work like it should
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Brakes
« Reply #3 on: May 01, 2007, 11:00:27 pm »
May be one of the following:
a-Air in the brake lines going to the rear----remedy, bleed the brakes very well starting with the right rear.
b-Either one or both of your rear drum adjustment sprocket is frozen or won't work. Remedy--Take the drums off and try to manually expand the (turn the sproket) threaded adjuster.
c-Master cylinder may be going bad...one resevoir controls the front, one the back. that is why you have two resevoirs in the brake master cylinder. The bigger pond controls the front brakes.
d-Ensure your wheel cylinders are working for your drum brakes.  It doesn't hurt anything the remove the shoes and take each wheel cylinder apart to ensure the little pistons are moving freely in them.
Just a few things to throw out there.
