Author Topic: 4wd Lock light question  (Read 7265 times)
Offline Prong
« on: May 13, 2007, 04:54:37 pm »
I recently picked up a 79 scotty with 350/SM465/NP205 setup. Should there be a 4wd lock bulb that comes on in the cluster like my other 79 that has a NP203 with a TH350? If so, it's time to start chasing wire  >:( and see where the problem lies.
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
Offline lt1kicker
Re: 4wd Lock light question
« Reply #1 on: May 16, 2007, 04:51:58 pm »
I just picked up a '79 Scotty last night and didn't see any 4x4 lamp.  Where would it be?  Of course I don't think a single light in my dash works....
Aj
1979 Chevrolet Scottdale 4x4, 350, 180k
1994 Caprice 9C1, LT1, G80
1995 Caprice 9C1, LT1, FOM9C1
www.fallenofficermemorial9c1.org
« Reply #2 on: May 16, 2007, 10:23:44 pm »
Both should have the lamps, it will be under the speedometer (in the recessed area)  Check the bulb to see if it is burned out.
Offline lt1kicker
« Reply #3 on: May 17, 2007, 08:40:50 pm »
Discovered my bulb is gone!  :D
Must be stuck on and PO got sick of it.  I'll reinstall.  If nothing else it will look cool.
Aj
Offline Prong
« Reply #4 on: June 10, 2007, 07:03:33 pm »
Finally tore the cluster out today (stupid clutch bracket in the way, and discovered there's no pigtail to plug into that socket. I looked high and low but couldn't find the 2 wire lead (white and pink/black IIRC). So either mine doesn't have it or it was removed. One of these days I'll have to crawl underneath and see if the switch is present on the T Case and go from there.
« Reply #5 on: June 10, 2007, 11:04:40 pm »
The light doesn't have a pigtail.  It is part of the printed circuit.
Offline Prong
« Reply #6 on: June 11, 2007, 01:05:23 am »
On my other 79, there's a 2 wire lead that ends in a socket that the bulb pops in to, and then you twist that on to the cluster case/circuit board.
Offline 1976Scottsdale
« Reply #7 on: August 05, 2007, 07:21:19 pm »
That would be on a 203 case, I have never seen one on a 205.  208 cases had them as well.
Offline Prong
« Reply #8 on: August 06, 2007, 12:18:47 am »
So I'm guessing there's no provision for the 205 and the 4wd lock light then? Just thought it would be cool to have another gadget to play with.
