Author Topic: WOO rusty leaf spring holder  (Read 5354 times)
Offline lt1kicker
« on: May 16, 2007, 04:32:22 pm »
79 Scottsdale 3/4 ton.  LH Rear leafspring bracket is rusted pretty bad.  Previous owner pointed this out, and we wondered if there is a direct replacement part to bolt in.  Is this common?  What would be the best method of fixing, weld it up or replace?
Aj
1979 Chevrolet Scottdale 4x4, 350, 180k
1994 Caprice 9C1, LT1, G80
1995 Caprice 9C1, LT1, FOM9C1
www.fallenofficermemorial9c1.org
Re: WOO rusty leaf spring holder
« Reply #1 on: May 16, 2007, 10:03:48 pm »
I don't know of anyone reproducing these.  I would get them off a donor truck and weld or bolt it in using grade 8 bolts.
Offline lt1kicker
« Reply #2 on: May 17, 2007, 07:26:12 am »
Thanks. I think it will be fine until winter.  I wish I had access to a sandblaster, then I'd get under this truck and clean things up so I could see how bad the rust reallly damaged things.  Gotta love GM sheetmetal!  I swear these trucks and B-bodies would rust away on the moon.
Aj
