Author Topic: Steering Column Differences?  (Read 11919 times)
Offline clubbert
« on: March 02, 2003, 10:09:00 pm »
I Want to switch to to a tilt steering column in my truck but not sure what all in need.  Do I need the entire column including shaft and all or just the housing up.  Also I noticed that there are two different ones in some catalogs one for
73-78 and one for 79-87.  anyone know the diff?  and which would I go by considering I have a 74 frame and a 82 body?
thanks
c
Column
« Reply #1 on: March 23, 2003, 09:01:00 pm »
Go with the year your cab is. The diference is that the wipers are in the directional switch handle on the newer trucks.
Offline jgray22
column
« Reply #2 on: April 15, 2003, 06:48:00 am »
Does a tilt column give you more room between you (stomach) and the steering wheel.  i feel so close when i drive.. Do they make different offsets in steering wheels !!!
Good luck with the column...
Jason
