Author Topic: TPI onto 86 Block  (Read 191705 times)
Offline 123 pugsy
Re: TPI onto 86 Block
« Reply #75 on: July 27, 2007, 05:18:38 am »
Some beautiful work! I bet you could fabricate a gas tank that would put Rock Valley to shame, and they build one heck of a gas tank!
Thanks,although I've never seen one of their tanks. I more than likely will be building a tank for my next project. Only problem is I don't have my next project car yet.You know.( Wife...babies....yada..yada...yada....)
« Last Edit: July 30, 2007, 06:22:14 am by 123 pugsy »
Pugsy
76 C10 LWB
TPI 350
Offline 123 pugsy
« Reply #76 on: July 30, 2007, 07:06:00 pm »
Bracket for the air filter box. I found an old A/C bracket and added a couple pieces of flat bar. Added a reinforcement,a 1/4" thick top plate and hit it with paint and good to go.
Pugsy
76 C10 LWB
TPI 350
Offline 123 pugsy
« Reply #77 on: July 30, 2007, 08:00:10 pm »
Made up a few more parts Sunday as my overflow tank has to be moved.Hope it will be large enough. :o
Got them welded up ..........
Polished and screwed in place.....
Pugsy
76 C10 LWB
TPI 350
Offline smlblock
« Reply #78 on: August 03, 2007, 08:15:39 pm »
that over flow looks great.  how to make me one lol
« Reply #79 on: August 08, 2007, 09:00:26 pm »
very nice pugsy!
Offline 123 pugsy
« Reply #80 on: August 08, 2007, 09:06:23 pm »
Thanks guys.
I should be ready to install the TPI soon. I'm just waiting for some 4" rubber 90* and 45* elbows and an EGR valve solenoid.
I don't know where to find 4" corrugated hose to go from the air filter box to the rad support air intake fitting.
Pugsy
76 C10 LWB
TPI 350
Offline 123 pugsy
« Reply #81 on: August 24, 2007, 05:14:14 pm »
Got the air intake hose done and the filter box mounted. Just need a piece of 4" hose from the filter box to the rad support and should be good to go. ;)
Pugsy
76 C10 LWB
TPI 350
Offline 123 pugsy
« Reply #82 on: August 25, 2007, 12:14:44 pm »
Well it looks like dryer duct is definitely out! ::)
Pugsy
76 C10 LWB
TPI 350
Offline cjtimp
« Reply #83 on: August 25, 2007, 01:25:11 pm »
You are a "Real man of genius!".......... ;D.....seriously tho....that looks great.
Offline 123 pugsy
« Reply #84 on: September 17, 2007, 07:41:48 pm »
Thanks cjtimp.
I dropped the tank and found some rust in there so I changed it for an 87  tank with the built in tray.Fuel lines are in and holding pressure. Whew!
Took off the crossover to install a metric stainless steel nut as the O2 sensor bung.
Pugsy
76 C10 LWB
TPI 350
Offline 123 pugsy
« Reply #85 on: September 17, 2007, 07:49:55 pm »
Almost done! Got a couple of wires to hook up ,throttle cable and a few other things to do before the trouble starts. I'll be throwing an EGR code as no one has an EGR valve solenoid.  They are back ordered from China. I guess they are too busy over there now as everything is being made there.GM is showing discontinued.
A couple of pics......
Pugsy
76 C10 LWB
TPI 350
« Reply #86 on: September 17, 2007, 08:38:16 pm »
Ask your GM dealer to locate you one. I'm sure someone has one in stock they can UPS you. Or try a few bone yards. www.car-part.com
PS Looks great man!
Offline CruzinHigh
  • Chevy 4 life
« Reply #87 on: September 20, 2007, 07:04:11 pm »
Awesome!  Your fabrication skills are fabulous!    :o
Mike Carter
1986 Chevy K-10 4x4
Offline 123 pugsy
« Reply #88 on: September 20, 2007, 07:29:22 pm »
Thanks guys.  :)
Now the fun begins.......  just turned it over and no start. I got to get my buddy over so he can turn the key while I check for spark.
How do I test if the injectors are getting power if I find I'm getting spark?......or any other method of how to start the diagnoses will be appreciated.  ??? ??? ??? :o :o :o
Pugsy
76 C10 LWB
TPI 350
Offline jays2w87
  • Bone stock..... Not for long!
« Reply #89 on: September 20, 2007, 08:42:28 pm »
Pugsy, I'm not one to butt right in, but I have to say. I have been reading you project and checkin out the pictures. That is one sweet rig ! Done really nice. Smooth and clean.
And the metal work youve done , wow!
Nice Job Man !
