Author Topic: how low is too low  (Read 8158 times)
Offline Mtrhd329
how low is too low
« on: May 29, 2007, 04:11:10 pm »
i am currently building a 79 silverado.  I am thinking of going with a 3/5 drop as this should not bee too low for a daily driver.  My question is will i still be able to control a boat trailer with the truck this low.  i know everyone says you can "tow" it just fine but i want to know how it will handle.  i have driven an s-10 "towing" a trailer and it was more the other way around.  Anyone got any inputs on this setup?
Offline bigblock73
  • Yeller
Re: how low is too low
« Reply #1 on: May 29, 2007, 06:48:48 pm »
With spindles and a flip kit it will handle the same as it did without the drop...if not better.  I wouldn't worry about it one bit.  If the truck squats too much with the flip kit, get some helper bags for the rear and you'll be all set.
Jeff
'73 swb 2wd
73-87.com
Offline Lon
« Reply #2 on: May 29, 2007, 07:28:47 pm »
I used to tow a car trailer with my 84 that had a flip kit. I only bottomed out once on a real bad road going to fast. It did squat a bit but I never had anything heavier than my sister's Nissan truck on the trailer. A boat should be no problem.
1984 GMC Sierra. Air Bagged but mostly stock.
Offline Mtrhd329
« Reply #3 on: May 30, 2007, 03:37:55 pm »
so there is still room int there for the little helper bags?  Who makes these?
Offline Lon
« Reply #5 on: May 30, 2007, 07:32:42 pm »
As long as the springs themselves dont move you have the same space as stock. All you are doing in a flip is moving the axle to the top of the springs.
Offline shaved80
« Reply #6 on: June 02, 2007, 12:10:35 am »
no such thing as too low ;)
Offline 1badgmc
« Reply #7 on: August 17, 2007, 01:37:49 pm »
The lower I go the more she likes it!  ;D The lower the better, man.
Jason
1988 Chevrolet Crew Cab Dually
1991 GMC Sportside
1998 Chevrolet Suburban
Offline 87GMC2WD
« Reply #8 on: August 17, 2007, 09:57:03 pm »
how much does flipping it drop it. say on a 2wd 1500 long bed?
« Reply #9 on: August 17, 2007, 11:38:07 pm »
Flip kits are generally 5-6".
