Author Topic: 2 inch lift block on my suburban? Are those any good?  (Read 6065 times)
Offline SLO 85 GT
« on: June 17, 2007, 08:06:28 am »
I want to install the 2 inch lift blocks on my 87 suburban with my air shocks...I'm doing this because i want the truck to stay at certain height when towing my Racecar and open trailer and i was gonna use the air shocks to keep everthing level....Is this setup ok?
Re: 2 inch lift block on my suburban? Are those any good?
« Reply #1 on: June 20, 2007, 10:39:30 am »
What about using Helper bags instead?  That way you will have the same ride and when you put a trailer on you can lift it up.
A 2" block should be ok though.
Offline SLO 85 GT
« Reply #2 on: June 22, 2007, 08:06:09 am »
Thats a good idea as well ;DI'll look into those today at work.
