Author Topic: th400 kickdown  (Read 3865 times)
Offline 83SN
th400 kickdown
« on: June 20, 2007, 08:18:12 am »
Having installed a th400, wiring the kickdown, attaching the part to the gas pedal, when i push the pedal all the way down, it does not touch the bolted on part.  Would i need the pedal assy from the donor vehicle?
83 Chevy S/N
454, 400....(almost ready)!!!
thanks
willie
« Last Edit: June 20, 2007, 09:33:34 am by 83SN »
Offline ccz145a
Re: th400 kickdown
« Reply #1 on: June 20, 2007, 09:12:38 am »
Going from memory here... I believe you pull back the spring loaded plunger on the switch and let go. Worked last time I did it, 15 years ago. and still downshifting haven't had to touch it since.
Good luck.
Offline joesgarage71
  • Wrench
Re: th400 kickdown
« Reply #2 on: June 20, 2007, 05:28:39 pm »
 If the arm isn't working the switch at or near WOT than something isn't right.Let me see I should have a pic somewhere.
Steve
