Author Topic: speedometer  (Read 4400 times)
Offline mikewb
speedometer
« on: June 21, 2007, 12:40:40 pm »
my speedometer was messed up . when i went to fix it i found out that the small plastic gear that runs it was chipped off. Can i just replace that gear? or will it just happen again.? what are some causes of this?
Re: speedometer
« Reply #1 on: June 21, 2007, 01:20:43 pm »
Yes you can replace it.  Age is the only thing I can think of that would break one, the cable could kink/bind but I wouldn't think it would break teeth off the gear.
Offline mikewb
Re: speedometer
« Reply #2 on: June 21, 2007, 03:00:44 pm »
soo you dont think if i replace it that somethin inside will do it again?
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: speedometer
« Reply #3 on: June 21, 2007, 03:25:26 pm »
That's how they calibrate speedos, by replacing the plastic gears. hopefully your's is not in the tranny floating around.
Offline mikewb
Re: speedometer
« Reply #4 on: June 21, 2007, 03:47:10 pm »
do you know if the gears are the same on a th350 as the one in the granny fourspeed manual that came out int hose years because i have several of those
