Author Topic: 2007 Rims  (Read 6258 times)
Offline 77GMCSerria
2007 Rims
« on: June 22, 2007, 09:41:18 pm »
Is there any way to put new rims like the Chevy 21" on a 77 C10? I want to try not to use adapters. Is there anything like changing rotors something? I know the new Chevy rims use a 6 lug pattern and the 77 uses a 5 lug pattern.
Offline red4wd
Re: 2007 Rims
« Reply #1 on: June 22, 2007, 09:47:36 pm »
You can have the front hubs and rear axles drilled for the correct bolt pattern.  If the 07's use the same 6x5.5 pattern you could also swap to 4wd axles and brake drums on the rear end.
Offline FlatBlack77
Re: 2007 Rims
« Reply #2 on: June 22, 2007, 10:15:58 pm »
If you would want to go a more expensive but perhaps simpler way, you might be able to get some brand new factory wheels without holes drilled in them and get them drilled for your bolt pattern.
but it would probably cost an arm and a leg.
Offline jrod
Re: 2007 Rims
« Reply #3 on: August 07, 2007, 06:46:17 pm »
2wd 3/4 rotors where 6 bolt  and 4x4 rear end out to do the job
Re: 2007 Rims
« Reply #4 on: September 01, 2007, 06:40:24 am »
I believe the 07s use a metric pattern, not the same as the old 6 lug pattern. When talking 73 / 87 all 3/4 tons use 8 lugs 2 and 4 wheel drive. You also have to consider that the new trucks have a different offset. The wheels are more like a front wheel drive car, the mounting face is closer to the outside of the wheel. Adapters might be your best best for a couple reasons. (1) to get the wheel out where it belongs in the wheel opening (2) to keep it from rubbing against frame / suspension parts when turning.
