Author Topic: Window frame  (Read 4867 times)
Offline 87GMC2WD
Window frame
« on: July 08, 2007, 08:29:04 pm »
Had anyone here expeirenced a truck that the two bottom corners around the window are starting to rot out? On my drivers side its gone all the way to the window. And does anyone have any suggestions on how to fix it?
Thanks, Kyle
Re: Window frame
« Reply #1 on: July 08, 2007, 09:20:45 pm »
Which window? You say window frame, the only thing I can think of is you vent windows in your doors. If they are what you are talking about you will need to replace them. If the body its rusted out you will need top weld in new metal?
Offline 87GMC2WD
Re: Window frame
« Reply #2 on: July 09, 2007, 04:30:36 pm »
sorry, i meant my around my windshield. When i lift up the gasket on the windshield i  can see that the hole goes all the way around the corner.
