Author Topic: project swb  (Read 22006 times)
Offline low3+3
some pics of my truck
« Reply #15 on: July 29, 2007, 04:59:29 pm »
made some progress over the week end.tore out all the front susp, bolted on 1/2 ton upper ball joints and had to plate the front of the lower arm so i could tack in 1/2 lower ball joints. choped a coil off the springs, bolted on my 1/2 ton spindles and brakes, then sanded every thing and gave it a hillbilly powdercoat(rustolem hamered paint   ;D)then threw on some rims and tires i had for the time being even though they're a bit small.big improvment for only spending 65 bucks
Offline low3+3
Re: some pics of my truck
« Reply #16 on: July 29, 2007, 05:01:51 pm »
finished minus the shocks
Offline low3+3
« Reply #17 on: July 29, 2007, 05:05:26 pm »
Offline Lon
« Reply #18 on: July 29, 2007, 05:33:05 pm »
Nice work!
To convert from 3/4 or 1 ton to 1/2 ton, all you did was swap to 1/2 ton balljoints? My neighbor is scrapping a 4 door 3/4 ton with 1 ton spindles and dually axle. If I get the truck I want to make a 1/2 ton 6 foot bed 4 door truck.
1984 GMC Sierra. Air Bagged but mostly stock.
Offline low3+3
« Reply #19 on: July 29, 2007, 06:14:18 pm »
yes the upper joints are smaller but they use the same bolt pattern and the lowers are smaller but i jut welded them in
Offline low3+3
« Reply #20 on: July 29, 2007, 06:15:49 pm »
oh and you need  the spindles from a 1/2 ton of course
Offline cubicdollars
« Reply #21 on: July 30, 2007, 05:22:56 pm »
I really think you should Make a Phantom dually. Get you some nice 15X14 rims for the back and reinstall the dually bed :o
« Reply #22 on: July 30, 2007, 06:51:46 pm »
what did you weld in?  ???
Offline bagged81
« Reply #23 on: August 05, 2007, 08:56:02 pm »
I was so close to making mine a crew cab be I chickened out.  Can't wait to see how this turns out.
Jeff C.
1981 Silverado - bagged, z'ed and 20's
Offline cjtimp
« Reply #24 on: August 06, 2007, 07:14:56 am »
Looks GOOD.....
Offline low3+3
project swb
« Reply #25 on: October 07, 2009, 02:55:31 am »
getting there
Offline low3+3
Re: project swb
« Reply #26 on: October 07, 2009, 02:56:44 am »
getting there
Offline oldwhity
Re: project swb
« Reply #27 on: October 07, 2009, 10:14:51 am »
That looks great. What frame are you using? I see the half ton running gear and maybe a 9in in the rear? Is it going to be a short bed or are the pics throwing me off?
Rob G.
81 Chevy K20 4x4 LWB stepside
Offline low3+3
Re: project swb
« Reply #28 on: October 07, 2009, 08:38:19 pm »
 thanks and your right its a 3/4 ton frame shortened with a 9 inch disk rear and 1/2 ton front , now airbaged with four link and raised front cross member
Offline oldwhity
Re: project swb
« Reply #29 on: October 08, 2009, 02:21:56 pm »
Oh I see now. When I last posted it didn't show the rest of the thread. Pretty cool!
Rob G.
