Author Topic: Help identifying brackets  (Read 9754 times)
Offline stevieray36
« on: July 10, 2007, 03:28:12 pm »
Does anyone know were I can get exploded diagrams of the power steering and air conditioner compressor brackets for a 82 c-10 w/350 SB. The truck originally had a 305. If anyone has pictures that might help identify and locate brackets email to steve.rayburn@smith-nephew.com.
I know I should have taken pictures, dropped my digital camera and need to replace.
Help!
Offline pcmcobra
Re: Help identifying brackets
« Reply #1 on: July 10, 2007, 09:19:43 pm »
Offline stevieray36
« Reply #2 on: July 11, 2007, 12:53:35 pm »
I have the alternator mounted and I have pictures of the power steering pump mounting.
All I need is pictures of the AC compressor mounted to a SB engine.
Again I have an 82 C-10 with a 350 SB.
Does anyone have this truck with air, if so could you take some pictures. It would be greatly appreciated.
I went to several used car lots and the three 80 model trucks did not have the compressor mounted.
Help!!
« Reply #3 on: July 11, 2007, 01:47:00 pm »
What kind of compressor is it?  Do you have pictures of the brackets you have?  If so we can tell you where they go.
Offline yttaf
« Reply #4 on: July 11, 2007, 06:13:22 pm »
Help!!
My 81 C-10 used to be a 305 swapped to a 350 with air. I'll take some pics when I get home...
Offline pcmcobra
« Reply #5 on: July 11, 2007, 08:26:33 pm »
maybe this will help?
Offline eventhorizon66
« Last Edit: July 11, 2007, 09:53:05 pm by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
Offline stevieray36
« Reply #7 on: July 12, 2007, 11:30:21 am »
Thanks for the pictures. There is a flat, triangular shaped bracket, large hole off center, and three holes one in each corner. Does anybody know were this is used?
« Reply #8 on: July 12, 2007, 11:58:43 am »
Post a pic of the bracket in question.  Or is your camera still out of service?
Does it have sort of a "leg" on one corner of the triangle?  If so you may be talking about a bracket that bolts flat to the cylinder head and supports the AC with the "leg" end.
It would be this one (directly behind the PS cap): http://i208.photobucket.com/albums/bb247/1985C10/P7110080.jpg
« Last Edit: July 12, 2007, 12:09:42 pm by eventhorizon66 »
Offline stevieray36
« Reply #9 on: July 16, 2007, 07:34:19 am »
I want to thank all those who responded. I got it all back together this last weekend. Next time pictures will be required before dismantling.
