Author Topic: core support  (Read 5278 times)
Offline the_legend_1981
core support
« on: July 10, 2007, 04:43:47 pm »
anyone know what i should do to change my core support without unbolting anything else?  i just need a walkthrough. thanks
Re: core support
« Reply #1 on: July 10, 2007, 05:48:51 pm »
There is no way to remove the core support without unbolting everything.  The fenders, inner fenders, frame, filler panel, and everything related to the grille connects to the core support.
Re: core support
« Reply #2 on: July 10, 2007, 07:33:23 pm »
sorry, what i meant was will i have to drain the radiator or can i avoid doing that?
Re: core support
« Reply #3 on: July 10, 2007, 09:47:26 pm »
It is possible to swap the support without draining the coolant. just unbolt the radiator and lean it against the fan. I would put a couple layer of card broad between them.
