Author Topic: 454 project  (Read 239343 times)
Offline jonkmbll89
Re: 454 project
« Reply #105 on: January 13, 2008, 12:23:31 pm »
Sounds great! ;D :o
Offline JRConnieK10
Re: 454 project
« Reply #106 on: January 13, 2008, 04:05:46 pm »
Man, that sounds nasty. In a very good way.  I'd like to see pics of it in, like a jewel in a box. Nice job.
'85 K10 LWB 350/SM465
BUILT NOT BOUGHT
Offline 86 chevy silverado
Re: 454 project
« Reply #107 on: January 13, 2008, 08:17:16 pm »
I've been dieing to do a hotrod 2wd truck. Sounds nice and nasty, what are you running for exhaust?
Re: 454 project
« Reply #108 on: January 14, 2008, 01:41:06 pm »
Thanks! It's 3" aluminized from the headers back with 3" flowmasters
Offline SUX2BU99
Re: 454 project
« Reply #109 on: January 14, 2008, 02:39:24 pm »
Wow, wicked sound. What RPM was it idling at?
Re: 454 project
« Reply #110 on: January 18, 2008, 07:07:22 pm »
In probably around 900.
Progress to date:
I've rewired the majority of the engine wiring with the exception of the heater wiring still. I installed the AC delete box and am hiding all of the wires. I'm also putting the blower motor resistor inside the cab as opposed to in the engine compartment heater box. I have to finish my fuel lines and install the new pressure regulator and gauge. I had a VDO gauge which is the 3rd one I've had that fell apart inside. Once that stuff is all done I will post some new pix. I also had to fabricate a power steering bracket since it wasn't lining up very well. Everything looks really good and once it's all buttoned up I'm going to start hacking up my suspension. :D
Offline nova801428
Re: 454 project
« Reply #111 on: January 18, 2008, 09:45:01 pm »
What are you going to do to the suspension?  -Air ride?
Your truck sounds REALLY good.  It is also VERY nice.  That is definitely one nice truck!!!
1975 Chevy k20 6" lift 35" BFG MT's True Dual Exhausts Radical Cam
1980 GMC 2500 Parts Truck
Re: 454 project
« Reply #112 on: January 19, 2008, 07:42:57 am »
Thanks. I plan on narrowing the frame, 4 link...I have to save up a bit to fund the project. For now I am thinking I might try the lowering leafs in the rear or a flip. I have Belltech drop spindles in the front and lowering springs. The rear is just shackles but I'd like to drop it another 2 inches.
« Last Edit: July 27, 2017, 02:41:32 pm by VileZambonie »
Re: 454 project
« Reply #113 on: January 26, 2008, 06:46:03 pm »
Well today I finished up all the wiring. I took all of the heater/ac wiring and ran it back through the firewall. I installed the blower motor resistor inside the cab and it looks so much cleaner and nicer. I painted and put the hood hinges on and took it out for it's first initial run and all I can say is HOLY CRAPOLA! It stuffed me back in my seat so hard my back cracked  ;) It just launches and pulls pulls pulls! As I was fine tuning it I started to run out of gas so I have to go make a trip for some 100 octane. I did get to leave posi strips all over the place though  ;D As soon as I get a new digital camera I will post more pix and video's. I still have to adjust the valves a little, play with the timing and put my wheel wells back in. After that I'm gonna take a little break from this puppy to fix a leak on my harley and get that thing all ready for spring before I start doing the suspension.
Offline RSBAD454
Re: 454 project
« Reply #114 on: January 26, 2008, 11:47:02 pm »
sweet ride, sounds great!!!!! I'll have to get sounds clips of mine once the weather clears up. 8)
http://
Offline Redneckchevy
    • Photo Bucket
Re: 454 project
« Reply #115 on: January 26, 2008, 11:56:30 pm »
I think ur truck would look good with a blower sticking out the hood ;)
Offline JRConnieK10
Re: 454 project
« Reply #116 on: January 27, 2008, 12:24:23 am »
At least a hood scoop right?  jus play'in. lol
BUILT NOT BOUGHT
    • Photo Bucket
Re: 454 project
« Reply #117 on: January 27, 2008, 12:34:36 am »
lol...I go for the opposite of a "sleeper" look ...V6 granny tranny and a hood scoop ..tach and Hurst shift knob on a 4x4
Offline JRConnieK10
Re: 454 project
« Reply #118 on: January 27, 2008, 12:39:49 am »
Redneck were is barberton? Is it up north?
BUILT NOT BOUGHT
    • Photo Bucket
Re: 454 project
« Reply #119 on: January 27, 2008, 12:49:09 am »
Town over from akron  im right next to 71...Just on the other side of ohio from ya...
« Last Edit: January 27, 2008, 12:54:39 am by Redneckchevy »
