Author Topic: 79 c-10 shortbed  (Read 5121 times)
Offline the383
79 c-10 shortbed
« on: July 18, 2007, 07:15:04 pm »
Does anybody know of manuals or other sources that has a good description of removing the bed from my 79 c-10 stepside?
Re: 79 c-10 shortbed
« Reply #1 on: July 18, 2007, 09:15:47 pm »
Just unbolt it or cut the bolts with a torch. Unplug the tail lights, disconnect the rear end vent tube, disconnect the fuel filler, and disconnect the ground wire from the bed to the frame. Get some buddies to help you lift it off.
Offline 77c15
  • combustion=suck, squeeze, bang, blow
    • My cardomain site...
« Reply #2 on: July 18, 2007, 09:44:53 pm »
A cherry picker helps if you have nobody to help:
Offline the383
« Reply #3 on: July 19, 2007, 06:23:45 am »
Thanks for the replies.
