Author Topic: Motor Mount Plates  (Read 4712 times)
Offline 78BBSTEPSIDE
Motor Mount Plates
« on: July 24, 2007, 10:34:18 pm »
Building a fresh frame for the next project (1/2 ton 2wd) consisting of a 75 frame and a 77 front crossmember. I went to bolt the motor mount plates to the frame and crossmember and the holes do not match, almost 1/2 inch off (just short of aligning) on the crossmember given the top side is bolted to the frame. I have motor mount plates from both a 3/4 ton and a 1 ton and neither fit. Is the motor mount plate unique to the 1/2 ton before I make a trip to the bone yard??? The rails are straight and is a no hit frame.
Re: Motor Mount Plates
« Reply #1 on: July 24, 2007, 11:38:09 pm »
If you are working on a 1/2T frame/crossmember, you need 1/2Ton pieces.
« Reply #2 on: July 25, 2007, 08:40:10 pm »
That's what I figured, guess it is time for a trip to the boneyard. I appreciate the input much.
