Author Topic: Speakers in door panel  (Read 21780 times)
Offline struggla
« on: July 26, 2007, 06:25:25 pm »
Hey guys i am looking at put some speakers in the lower carpeted area of my door panel.
Can anyone suggest a good location for them as to avoid braces, and window regulator etc.
If anybody has pictures i would love to see the location you mounted your speakers at.
I am thinking about installing some round 5 1/2 speakers.
Offline FlatBlack77
Re: Speakers in door panel
« Reply #1 on: July 26, 2007, 11:17:18 pm »
It's not my truck but it's all I could find.
Shot at 2007-07-26
Offline struggla
« Reply #2 on: July 27, 2007, 05:19:32 pm »
Thats cool, thanks. I want to put my speaker up front and just wanted to see if there was room void of braces or window mechanisms there.
Online Captkaos
« Reply #3 on: July 27, 2007, 05:54:05 pm »
Make sure they are water resistant speakers if you are going to put them there.  A lot of water gets down in there.  We have kick panels that house a 6.5" speaker in the catalog here:  http://store.73-87chevytrucks.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=7&Product_Code=RD-3061&Category_Code=7387INT
Offline eventhorizon66
« Reply #4 on: July 28, 2007, 05:34:49 pm »
I agree with Captkaos.  Kick panels are the best way to go.  The speaker imaging would be much better.
'85 C10 SWB 350 700R4 TKO600
« Reply #5 on: July 31, 2007, 05:07:04 pm »
Without looking up the link, is the emergency brake lever in the way???
« Reply #6 on: July 31, 2007, 09:40:32 pm »
I'm not sure, but its close.  Some kick panels require putting a slight "z" bend in the parking brake pedal, or using a spacer to move it to the right a bit.  Not sure about this one, but the fix isn't difficult if you find there is interference.  In my opinion its worth the trouble for the dramatically improved imaging.
Online Captkaos
« Reply #7 on: August 01, 2007, 03:46:38 pm »
You will have to adjust the parking brake to not use the whole amount of travel, or you can shorten up you parking brake, this is pretty much required on any kick panel speakers.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=4993.msg23384#msg23384
« Reply #8 on: August 03, 2007, 07:10:16 pm »
Thanks Chris for the link.  I need to replace my parking brake assembly anyway because it is worn out so spacing it out a little should be no problem.  Do you have info on where I could get me some.  Thanks in advance.
Online Captkaos
« Reply #9 on: August 04, 2007, 10:32:03 am »
....so spacing it out a little should be no problem.  Do you have info on where I could get me some.
What do you mean by spacing it out?  I am talking about cutting the pedal and making it shorter, or adjusting the cable so it only goes down to before it hits.
Info on where to get some what?
« Reply #10 on: August 05, 2007, 08:04:32 am »
Some what?? Kick panel speaker housings....
Online Captkaos
« Reply #11 on: August 05, 2007, 10:19:24 am »
You can order the kick panels out of our catalog at the link I posted.
« Reply #12 on: August 05, 2007, 12:12:05 pm »
Thanks, I figured it out.  I guess I have to look more closely to the replies.  I didn't realize the catalog existed until I looked around.
Online Captkaos
« Reply #13 on: August 05, 2007, 02:57:54 pm »
Gotcha, a link to our catalog is tied to the logo at the top of the forums.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #14 on: February 06, 2008, 09:54:06 pm »
Go straight back about 3 inches from where the front of my speakers are...   i screwed up and put em too far forward and had to cut into about an inch of the inner brace.  that was not fun and took many more jigsaw blades than i originally planned.. ;D  That's all that's in the way, except in the center of the door.
