Author Topic: build sheet  (Read 7856 times)
Offline gold84gmc
build sheet
« on: July 29, 2007, 07:59:13 pm »
does anyone know if the 73-87 trucks have a build sheet under the seat? or if its somewheres else or if it even has one?
92 buick century custom 3.3L
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: build sheet
« Reply #1 on: July 29, 2007, 08:48:19 pm »
The RPO sheet should be in the glove box.  You can find a site that lists each code. Someone reading this can probably link to a website.
This is the one from my  91 GMC suburban
Re: build sheet
« Reply #2 on: July 29, 2007, 11:37:52 pm »
It is either under the hood on the inner fender or most likely in the glove box.
www.73-87.com has the RPO codes.
Offline gold84gmc
Re: build sheet
« Reply #3 on: July 30, 2007, 06:47:33 am »
well i have a very short undetailed one on the inner fender, and i have another one in my glove box that dosnt say much...thats weird, cuz in my caprice i found a build sheet about the size of regular printer paper under my rear seat that listed an rpo about everything single thing
Offline cochese
Re: build sheet
« Reply #4 on: July 30, 2007, 10:12:28 am »
i found this on another 73-87 website-
you can try to call GM at the number listed in the link below.  i haven't tried it yet, but supposedly you give them your vin number, and they send you a pretty detailed packet about the stuff that should have come on your truck from the factory along with some other info (called a "restoration packet").  it's free, but it will probably take a few weeks.  check it out.
http://www.73-87.com/7387info/7387info_packets.htm
1986 c-10
305 5.0 V-8
Re: build sheet
« Reply #5 on: July 30, 2007, 12:26:20 pm »
The INFO pack lists what could come on the truck, not what actually came on it.  I have a couple of them.
