Author Topic: i needo a speedo  (Read 5171 times)
Offline steve
i needo a speedo
« on: August 03, 2007, 08:20:37 pm »
so i have an 83 c20 with a 350 and i just replaced my old busted th 400 with a slightly newer 700 r4, but i realized that the th 400 used a mechanical speedometer and the 700 r4 uses an elecrical one.  i was wondering if there are any apapters out there i could use or if i'm just better off getting a whole new speedo.  and any good deals you guys might know of would really be appreciated! thanks
1983 c20 350
Re: i needo a speedo
« Reply #1 on: August 04, 2007, 10:28:07 am »
700R4's came with mechanical speedo cables, you need the mechanical gear set out of one,
What year did your 700R4 come out of? 88-93?
This is what it looks like:
Offline steve
« Reply #2 on: August 05, 2007, 02:21:39 pm »
i'm not 100% percent sure but i think it's an 88.
1983 c20 350
« Reply #3 on: August 05, 2007, 02:52:51 pm »
You can get the mechanical pieces from any transmission parts store, being an '88 it would have the electronic VSS.
Offline steve
« Reply #4 on: August 06, 2007, 03:48:12 pm »
do i need to know any specifics about the car before i buy the gears?...tire size, rear end ratios anything like that?  and once i have the gears in the tranny do i just hook up the old speedo cable to it?
1983 c20 350
