Author Topic: question bout tall valve covers and a/c compressor  (Read 4758 times)
Offline 80stepsideguy
« on: August 05, 2007, 10:25:43 am »
Question,
im interested in putting a set of tall valve covers on my motor once it is installed, now with either a small block motor or a big block motor will i run into clearance issues if installing a set of tall covers or should i go with a low profile setup?
thanks
pat
1998 Chevy 1500 S/B 2wd
Re: question bout tall valve covers and a/c compressor
« Reply #1 on: August 05, 2007, 10:37:39 am »
What kind of compressor do you have?  The long style or the short style?  The long will have issues.
« Reply #2 on: August 05, 2007, 05:35:16 pm »
that i dont know right now chris, the truck doesnt have a a/c compressor at all but did the trucks come with the short style a/c compressor?The big block a/c brackets i got are for the long style compressors.
thanks
pat
« Reply #3 on: August 06, 2007, 11:42:32 am »
Yes, the later ones did.  I don't remember the year though.  I would guess and say 81 because my 81 had it, but may have been before then.
Offline okuma
« Reply #4 on: August 18, 2007, 05:00:27 pm »
I just did this myself on my 81 gmc with a short block. I intalled tall style mickey thomson valve covers, but i had to remove and set aside the short style compressor. After I installed the tall cover I was able to replace the compressor to its location with the original brackets! Not a problem!
