Author Topic: Please read, and help.  (Read 4627 times)
Offline 5004man
« on: August 06, 2007, 05:31:52 pm »
Ok I have a 85 2wd long bed. I want to know if I can run 15x10eagle alloys with 3 5/8 back spacing on the rear, and 15x8 3 1/4 backspaing up front. The rear tires will be 295/50/15 and fronts will be 235/60/15 this truck WILL have a 4/6 drop soon. That is the most backspacing I can find with those wheels, so will they tuck up in the fenders nice? I have tried to figure it out by measuring and it looks like they wont fit. Please reply if you know if they will or not. Thanks
Re: Please read, and help.
« Reply #1 on: August 06, 2007, 05:36:09 pm »
Negative, you need at least 5 on a 10" rim on the back.  Best way to figure out is measure the space you have now and figure at leas 1-1.5" clearance on front and backside of the tire.  The fronts might work, but again, I would measure.
Offline 5004man
« Reply #2 on: August 06, 2007, 05:59:16 pm »
How about if I go with the 16in rims with the 10s having 4.5bs and the 8s 4in bs, then running a 295/50/16 and a 265/60/16, the only problem with this is that the front tires will be 1in taller. Will this look weird? Thats the shortest tire I can find for the 16in ???. SO this means that if I want the same height I cant use 15s or 16s. Im really starting to get dissapointed about this...
« Last Edit: August 06, 2007, 06:53:31 pm by 5004man »
« Reply #3 on: August 06, 2007, 07:50:30 pm »
What are you wanting to do?  I would find someone that offers the size you want in the backspacing you need if you are wanting something specific.
