Author Topic: HELP ME!!! REAR BUMPER BRACKETS ????  (Read 6096 times)
Offline okuma
« on: August 11, 2007, 06:27:43 pm »
 I HAVE A QUESTION ON THE REAR BUMPER BRACKETS ,  DO SUBURBAN REAR BRACKETS FIT A TRUCK?     I NEED TO MOUNT THE SMOOTH FRONT REAR BUMBER ON MY CHEVY. I NEVER IMAGINED MY BRACKETS WERE DIFFERENT FOR THIS BUMPER... >:(
Re: HELP ME!!! REAR BUMPER BRACKETS ????
« Reply #1 on: August 12, 2007, 09:03:12 am »
From a Suburban/Blazer: Outers are the same, inners are not the same.
BTW: Step bumpers for a pickup are nothing like the factory bumper, so none of the brackets will work.
Offline okuma
« Reply #2 on: August 12, 2007, 10:19:19 pm »
THANKS ,  DOES ANYONE HAVE A SET OF BRACKETS YOU WILLING TO SELL?
« Reply #3 on: August 14, 2007, 11:17:30 am »
We sell the truck versions new in the catalog.
Offline Leadfoot
« Reply #4 on: August 14, 2007, 12:35:39 pm »
Okuma,
 Chris is right,outer brackets work,inners from the burb do not..but can be easily fabbed,the are simply a flat plate with 4 holes drilled in it.. bolt your bumper up into position using the outer brackets and make a carboard template to make the inners..if you got a way to cut a little steel and drill some holes,it'll be no problem ;D
Offline okuma
« Reply #5 on: August 14, 2007, 06:40:22 pm »
THANX LEADFOOT I WILL TRY THE CARDBOARD THING. ;D
