Author Topic: Hard starting when cold  (Read 5125 times)
Offline jandj_davis
« on: August 21, 2007, 11:55:21 am »
I recieved an 85 C10 as a hand-me-down from my grandfather. It runs well (as far as I know) and has so far gotten a new battery, alternator, fuel filter, and air filter. It has a E4ME carb on a 305 V8. The biggest issue I have with it right now is that after it sits for several hours (overnight, or all day at work) it takes a lot of cranks to get it started, and I am worried that I am going to wear out my starter. It starts fine (,2 seconds of carnking) when warm. I am moderately mechanically inclined, and do almost all of my own work on my motorcycles and this truck. I have a service manual (Chiltons), and under hard starting it says to check these things:
1. Binding linkage, choke valve or choke piston
2. Restricted choke vacuum diaphragm
3. Improper Fuel Level
4. Dirty, worn, or faulty needle valve and seat
5. Float sticking
6. Faulty fuel pump
7. Incorrect choke cover adjustment
8. Inadequate choke unloader adjustment
9. Faulty ignition coil
10. Improper spark plug gap
11. Incorrect ignition timing
12. Incorrect valve timing
I plan on replacing the spark plugs and wires very soon, and will gap them properly, but the truck runs and idles fine (idle may hunt a bit) so I don't think plugs are the main cause. Since I am new to 4-wheel maintenance, I have a few questions about the items listed above. (Note: I gave them numbers so they are easier to reference. They in no way represent priority.)
1, 2, 7, 8: I don't even know what these mean. Can anyone explain? It has an electrically controlled choke, so do they even apply?
3, 4, 5: Does the carb have to be removed/dissassembled for this to be addressed?
12: Does this require valve cover removal, or engine removal?
Finally, if any of you can recommend a plan of attack for me, I would appreciate it. Like I said, I will be replacing the spark plugs/wires very soon, but if that doesn't fix it, do I look at timing? fuel pump? choke stuff? if you could renumber the above list with a priority rating, which would come first? Thanks all!
« Last Edit: August 21, 2007, 12:07:20 pm by jandj_davis »
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Hard starting when cold
« Reply #1 on: August 21, 2007, 08:12:59 pm »
I think it is choke adjustment.  I never had an electric choke, but on a manul, i would just turn to coil some.
Here's a way to check.  Next time it sits overnight, push accelerator one time then pop the air cleaner and see if the choke is in the closed position.  (The flap in the carb should be closed shut, you won't be able to look down into the carb)  Being electric, you may have to have key half way on.  It should be closed, limiting the air coming into the carb when cold. If it is, then it is not a choke problem.
Watch to see if when the engine warms up, the choke should gradually open up allowing more air in.
« Last Edit: August 21, 2007, 08:17:46 pm by SgtDel »
Offline jandj_davis
« Reply #2 on: August 22, 2007, 08:22:56 am »
Thanks.  I'll give that a try this weekend.  If the choke does not operate correctly, what course of action should I then take?
