Author Topic: Painting Leaf springs??  (Read 10596 times)
Offline Rockin77
« on: August 29, 2007, 09:13:12 pm »
Is it ok to paint my leaf springs on my truck with spray paint??
« Last Edit: August 29, 2007, 09:16:58 pm by Rockin77 »
1977 GMC High Sierra 25
Offline FlatBlack77
Re: Painting Leaf springs??
« Reply #1 on: August 29, 2007, 10:10:28 pm »
sure
Offline bfofish
« Reply #2 on: August 29, 2007, 10:19:53 pm »
Better buy a case !  You will might have to repaint them allot. ;D
« Reply #3 on: August 30, 2007, 07:01:34 pm »
If you are not planning on sandblasting them I would use a brush. I would also recommend a product called Chassis Saver. It is identical to POR15 but about half the price. Wire brush the heck out of or needle scale them, then brush it on.
Offline okuma
« Reply #4 on: August 30, 2007, 07:28:25 pm »
ROCKING77, did you think spray painting your leaf spring would affect suspension?   OR hwy that question?     ------ I am just curious' ---- :-\   if you want you can even paint your tires and it will still be ok.
Offline Rockin77
« Reply #5 on: August 30, 2007, 09:35:15 pm »
I thought if i get it in the bushings or something that it would cause a problem. Sorry about the question i guess it was dumb
Offline FlatBlack77
« Reply #6 on: August 30, 2007, 09:55:29 pm »
I've done it.
Offline elegy_c10
« Reply #7 on: September 06, 2007, 10:01:24 pm »
I've done it.
me too...then i did a blue burnout
« Reply #8 on: September 07, 2007, 09:31:19 pm »
No question is stupid, well almost no question. But if you don't know you should ask. Or just do it and see what happens.
Offline jays2w87
  • Bone stock..... Not for long!
« Reply #9 on: September 21, 2007, 09:26:32 pm »
I ALWAYS paint my springs frame all that stuff. I advise is semi flat or regular flat black. looks awesome and hides alot! Unless you goin for a full restoration and you blasting them like mentioned above. Otherwise if you use a gloss or laqr paint you will see every little pit mark , dimple , and rust welt.
I also I'm guilty of painting a set of tires ....... They were white letter and they just didnt look right.... til I painted them.
Offline bigblock73
  • Yeller
« Reply #10 on: September 23, 2007, 09:25:46 am »
I blasted my leafs and gave them an aerosol overhaul...turned out great!!
Jeff
'73 swb 2wd
73-87.com
Offline 1tonson
« Reply #11 on: October 05, 2007, 10:42:29 pm »
An old chassis guy told me years ago. that you should inspect and clean then spray on graphite paint. tractor suppy has it.
