Author Topic: 350 Motor Install  (Read 5749 times)
Offline JJSZABO
350 Motor Install
« on: August 31, 2007, 08:48:09 am »
Hi Folks  :)
It's been awhile since I last posted but been busy on the ole gal.  I am installing the crate 350 when I noticed that the motor sits at a slight angle (10 degrees from horizontal) - tilting toward the rear.  This is with the Th400 trans and driveshaft installed.  I was always told that the carburator needs to sit level.  I forgot to notice if it was like this when removed the original motor.  Do I need a higher trans mount to "lift" the rear of the motor to level it out or, leave it as it is?
Any thoughts....
Thanks
Jeff
1986 C-10 short bed
Fleetside
350 crate motor (stock)
TH400 Trans
Jeff
86 Chevy C-10
350, TH400
Re: 350 Motor Install
« Reply #1 on: August 31, 2007, 11:05:34 am »
If you just pulled the motor out and put it back in and you are using the stock stuff, the angle is correct.  It should be more like 3-4 degrees though for the driveline.  The intake manifold is planed level for the angle of the motor being installed.
Offline JJSZABO
« Reply #2 on: August 31, 2007, 12:34:41 pm »
Thanks - That answers the question.
Removed the old 350 and installed the new crate 350 with edelbrock intake manifold (decided not to use stock intake) - no other changes.
Thanks again.
By the way,  almost finished with the cab sheet metal work - will post picture when finished.
Jeff
Jeff
86 Chevy C-10
350, TH400
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #3 on: September 01, 2007, 10:26:37 pm »
Jeff please do post pics of your cab when your done I can't wait to see them.
Offline JJSZABO
« Reply #4 on: September 02, 2007, 07:32:06 pm »
go to http://forum.73-87chevytrucks.com/smforum/index.php?topic=5661.0 to see the latest pictures
Thanks for looking
Jeff
Jeff
86 Chevy C-10
350, TH400
