Author Topic: Translation!  (Read 5529 times)
Offline Bitzer!
  • Smiles per gallon
Translation!
« on: September 14, 2007, 07:40:15 am »
Guys I need help (not that sort  :D)
I know the basics ie Hood = bonnet!
I'm trying to find a replacement part but unsure what you guys call it!
In the UK we call the inner and outer sills. Its the curved panel you see that runs the length of the cab under the doors that welds up to the bottom of the door opening. So if you are sat in the cab, opened the door and put your left hand down its the curved panel that runs underneath.
Any help please as I'd rather replace in full rather than weld plates over the rusty bits!
thanks
Andy
1979 GMC CrewCab  C20 1t
Offline ccz145a
Re: Translation!
« Reply #1 on: September 14, 2007, 07:47:12 am »
That would be the rocker panel. It is always good for us to know the Brit terms, too. So, keep asking.
Offline Bitzer!
  • Smiles per gallon
Re: Translation!
« Reply #2 on: September 14, 2007, 07:55:29 am »
thanks for a supa speedy reply! I've done a couple of UK Fords in the past but this is my first real "big" project  ;D
Feel free to fire over any questions, if I can help I sure will   :)
Offline Bitzer!
  • Smiles per gallon
Re: Translation!
« Reply #3 on: September 14, 2007, 10:55:47 am »
Another one!  HEI? i'm guessing its a type of fuel injection system?
Offline 1973c20
Re: Translation!
« Reply #4 on: September 14, 2007, 11:06:25 am »
HEI is actually part of the distributor. It essentially replaces the ignition coil and wire with a miniature coil mounted on the distributor itself.
Re: Translation!
« Reply #5 on: September 14, 2007, 11:08:19 am »
HEI = High Energy Ignition.  Replaced points in 1975 and went to ESC (Electronic Spark Control =CRAP) in 1981 on the trucks.
Offline Bitzer!
  • Smiles per gallon
Re: Translation!
« Reply #6 on: September 14, 2007, 11:09:58 am »
you guys are simply the dogs rear swingers  ;D  that IS a compliment- promise
