Author Topic: Can't get '79 Scottsdale to start  (Read 22782 times)
Offline lt1kicker
Re: Can't get '79 Scottsdale to start
« Reply #15 on: September 28, 2007, 03:09:06 pm »
Hey guys,
Grounds are all tight, but some of the connections on the starter are rusty.  Of course this wouldn't effect the igntion accessories.  I am afraid this problem is in the column.  Another problem I'm faced with is that all the wires coming out of the column have green paint completely covering them from where a PO sprayed the interior green.  This prevents me from being able to identify specific wires.  I'll start dropping the column tonight and see what I can find.  I'm surprised it went all at once.  I never had any indication of trouble.
Aj
1979 Chevrolet Scottdale 4x4, 350, 180k
1994 Caprice 9C1, LT1, G80
1995 Caprice 9C1, LT1, FOM9C1
www.fallenofficermemorial9c1.org
Offline okuma
« Reply #16 on: September 28, 2007, 04:56:48 pm »
then there a quick solution for your problems!!  there's nothing a match an a can of gas won't solve!........j/k ;D
Offline lt1kicker
« Reply #17 on: October 08, 2007, 06:31:29 pm »
I wish.
New starter, replaced battery, new ground wires, connectors, nothing.  No lights, no start.
Aj
« Reply #18 on: October 08, 2007, 10:04:38 pm »
I think you missed quite a few good suggestions here:
#1 do you have b+ at the S terminal on the starter solenoid when cranking?
#2 did you check your fusible links?
#3 did you check the rack mechanism for the ignition switch?
Offline lt1kicker
« Reply #19 on: October 09, 2007, 08:41:37 am »
I have power to the S on the starter.  I don't know where the fusible links are located on this truck (don't have a manual) and I don't know anything about them really.  As far as the "rack mechanism" no, honestly, I dropped the column, and bolted it back up.  I haven't a clue how to go about checking anything inside it.
Aj
« Reply #20 on: October 09, 2007, 07:10:49 pm »
You have B+ at the S terminal when cranking but the starter doesn't crank?
Offline KojaK 79k10
« Reply #21 on: October 09, 2007, 09:05:35 pm »
Fusible links are at the firewall usually near the brake booster. the wire is not copper so it acts like a fuse and lets out the magic white smoke of you overload it. you will usually be able to tell if that is the case.
77 Chevy swb "race truck"
*SOLD* 79' k10 Silverado SWB "Kojak"
truck is gone but not forgotten, worst thing I ever did was sell this truck and I regret it everyday.
Offline lt1kicker
« Reply #22 on: October 21, 2007, 08:34:10 pm »
Discovered a smoked fusible link last night. It was located running in the main harness, behind the motor, where it joined a tie point on the firewall behind the air cleaner. I replaced it today and I still have no electrical power. No headlights, no nothing. I cleaned connections at the voltage regulator as well and no change. I'm starting to get extremely pissed at this stupid truck.  I'm out of ideas.  This truck isn't that electrically complicated for crying out loud.  Not sure where to go from here.... ??? >:( ::)
Aj
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #23 on: October 21, 2007, 08:54:39 pm »
There is another fusible link within a foot of your starter...that is the main hot positive leaving the solenoid.
You just need to see where you get volts---coming into the fuse box, at your new fusible at firewall, where ever. Then troubleshoot from there.
