Author Topic: Mutt Project  (Read 785372 times)
Offline eventhorizon66
Re: Mutt Project
« Reply #150 on: November 16, 2009, 09:17:45 pm »
No problem.  Can't wait to see it finished.  I've been kinda researching just how cheaply I could swap my truck over to TBI.
« Last Edit: November 16, 2009, 09:23:38 pm by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
Offline Grover 1
Re: Mutt Project
« Reply #151 on: November 16, 2009, 10:30:54 pm »
Gunna go with Vintage Air or just leave it non air?
1978 C-10 SWB
1986 K-10 SWB
1975 C-10 SWB
And here I sit so patiently
You have to pay to get out of
Re: Mutt Project
« Reply #152 on: November 17, 2009, 06:36:21 am »
For now I'll leave it non AC. If I decide to keep the truck and love it I will add AC later but for now I just wanna git r done!
Offline SUX2BU99
Re: Mutt Project
« Reply #153 on: November 17, 2009, 10:12:59 am »
Is that an Edelbrock intake or a Professional Products? If it's a PP, how do you find the quality?
Re: Mutt Project
« Reply #154 on: November 17, 2009, 10:17:35 am »
PP, it's fine. It's not mint but it's a lot cheaper and does the job. Edelbrock lost my respect when they openly admitted to me they are re-badging most of their products.
Offline murraygmc
  • 85 gmc 4x4
Re: Mutt Project
« Reply #155 on: November 17, 2009, 11:10:43 am »
hay vill im still learning but what is that littel hose sticking out of the front of your intake ?
85 gmc high serria 4x4
Re: Mutt Project
« Reply #156 on: November 17, 2009, 05:34:44 pm »
It's the bypass hose. The Vortec intake retrofit
This intake manifold is primarily intended for use with Vortec heads on pre-Vortec blocks. Standard
engine blocks route thermostat bypass water from the block directly to the water pump through the passenger side water pump mounting flange.  You must route a thermostat bypass hose from the water bypass port on the front of the manifold to the 5/8” hose nipple on the passenger side of the Vortec water pump. Use a 3/8” pipe to 5/8” hose nipple fitting, and a 7” length of 5/8” hose to accomplish this. If your engine block has the thermostat bypass passage, use the 3/8” NPT plug supplied in the kit to plug the bypass port in the front of the intake manifold.
Offline SUX2BU99
Re: Mutt Project
« Reply #157 on: November 17, 2009, 07:06:30 pm »
Yeah the prices of the PP air gap are sure tempting vs. the E-brock. Since it's a non-moving item, as long as their isn't visible core shift on the runners lining up with the heads, should be fine. The Chinese are some of the finest reverse-engineers and design copiers out there!
Offline murraygmc
  • 85 gmc 4x4
Re: Mutt Project
« Reply #158 on: November 18, 2009, 11:31:52 am »
o cool . why do you want to bypass your thermostat ? why not just take it out ?  no offense just asking
Offline Jasper
Re: Mutt Project
« Reply #159 on: November 24, 2009, 03:23:34 pm »
any idea where that grille came from? i like...
1982 Chevy Silverado K10-6.2 Detroit Diesel
1998 GMC 2500 Suburban-6.5 Detroit Turbo Diesel
Lookin for another truck...
Re: Mutt Project
« Reply #160 on: November 24, 2009, 03:54:37 pm »
What grille are you referring to?
Murray, you do not want to bypass the thermostat, it's for the bypass side of the thermostat. The thermostat is still in there doing it's job but you still need coolant to circulate through the engine and heater core.
Offline Grover 1
Re: Mutt Project
« Reply #161 on: November 24, 2009, 07:42:09 pm »
So, if I buy an Edelbrock and it says Made in USA it might not really be made here?  Nice truck by the way.
1978 C-10 SWB
1986 K-10 SWB
1975 C-10 SWB
Re: Mutt Project
« Reply #162 on: November 24, 2009, 07:56:53 pm »
I'm fairly certain their intake manifolds are still produced in the USA.
Offline 80stepsideguy
Re: Mutt Project
« Reply #163 on: December 30, 2009, 09:24:08 pm »
Vile,
Ok whats going on with the projects??? We havent seen anything since the paint on the 454 for your green blazer. You gotta give us some updates on these toys as well as pics....
thanks
pat
1998 Chevy 1500 S/B 2wd
Re: Mutt Project
« Reply #164 on: December 30, 2009, 09:32:21 pm »
Well as you may have noticed by me selling crap in my garage I cleaned up and got everything situated to start back on my 74 which is may main focal point now. The MUTT is 90% wired up for the EFI and I'm hoping to have that running and driving in the next few weeks. I just ordered an extension housing and ouputshaft along with the rest of the parts for the 4L80E for the 75 Blazer(gotta convert it to 4wd) and I just scored a new engine to start building for possibly the pink truck. I'm planning a twin turbo V8 for that  ;). So as if I don't have enough of all that going on I'm dealing with daily life...blah! I just put satellite radio in my jeep. Goin to test it out now. How's your rig coming along? Did you get that other truck?
