Author Topic: front springs  (Read 6966 times)
Offline 1978 3/4
front springs
« on: October 11, 2007, 09:02:21 pm »
if i remove lift blocks from rear,1978 3/4 Chevy,the fronts going to be high ,because i had a shop install stiffer coils ten years ago,how hard is it to install stock springs at home ? I'm trying to get the stock ride back
Re: front springs
« Reply #1 on: October 12, 2007, 10:19:18 am »
Coils?  This is a 2WD truck?  It is pretty easy to install, just be careful.  You have to jack the front up and remove the wheel, and lower shock mount.  Then you have 2 options.  Remove the rear U-bolts connected to the crossmember OR remove the lower ball joint.  I highly recommend putting a jack under the spring pocket THEN removing whichever you choose and then releasing pressure lowering the control arm.
Offline 1978 3/4
Re: front springs
« Reply #2 on: October 12, 2007, 07:33:02 pm »
Yes its a 2wheel drive,first I'm going to lower the rear to stock spec's
I think its 34' and then fig front 32',the previous owner had a big cab over camper on it,so he must have installed 1.5 lift block on rear,
and he may have added leafs to spring,I think thats why the ride sucks! when replacing frt coils
manual states to get sprig compressor,is that right?
ps how do I get a jpeg on this site?
Offline JJSZABO
Re: front springs
« Reply #3 on: October 12, 2007, 07:54:20 pm »
Please - use a chain through the spring just in case the spring lets go.  You would not want to be in the path of the spring if it does. :o  I put new coils on mine and it wasn't that hard.
To add a picture, upload the jpeg to a photo sharing site like photobucket.com, then copy the file from photobucket and add it to this site.
« Last Edit: October 12, 2007, 08:01:32 pm by JJSZABO »
Jeff
86 Chevy C-10
350, TH400
Re: front springs
« Reply #4 on: October 13, 2007, 09:36:15 pm »
when making a post go expand the additional options link and you can upload them from your computer.  Just hit the browse button and find it on your computer.  It MUST be less than 192kb.
Offline 75 C20
Re: front springs
« Reply #5 on: October 14, 2007, 08:04:35 pm »
when i redid the steering and ball joints in my 79 i put cahins around the springs then just slowly let them down with a floor jack- it worked pretty slick and i was gald i put cahins on them cuz the one did kinda bounce out
you might want to think about doing ball joints while you got it apart
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
