Author Topic: Translation!  (Read 5145 times)
Offline Bitzer!
  • Smiles per gallon
Translation!
« on: October 15, 2007, 01:03:40 pm »
Hi guys and gals- me again!
I need to know - where the hood meets the windshield theres a panel that runs the width of the hood about 6" wide that sits "under" the hood if that makes sense. We call it the scuttle panel what do you call it and can you still buy them!
When the hoods closed you cant see it!!
cheers
Bitzer
1979 GMC CrewCab  C20 1t
Offline werewolfx13
Re: Translation!
« Reply #1 on: October 15, 2007, 01:29:56 pm »
its called a cowl, I'm not sure if you can buy em or not..I've never seen one that needed to be replaced..
Chris
'83 Chevy c10 Silverado SWB
Offline 123 pugsy
Re: Translation!
« Reply #2 on: October 15, 2007, 02:06:18 pm »
The plastic screen is available, but no actual sheet metal.
Pugsy
76 C10 LWB
TPI 350
Offline Bitzer!
  • Smiles per gallon
Re: Translation!
« Reply #3 on: October 15, 2007, 04:29:45 pm »
Unfortunately it rains loads overe here and I guess it held water in that area 'cos its rotted through. Looks like hood/fenders off and get the welder out!
Re: Translation!
« Reply #4 on: October 15, 2007, 08:03:43 pm »
Yep it is the cowl area.  They are KNOWN for rotting from not being cleaned out often enough.  Dirt, leaves, mud, etc can get caught in the seal and will sit there and rot though.  If the seam sealer is gone you will need to add some more back when you are done repairing it.
Offline werewolfx13
Re: Translation!
« Reply #5 on: October 16, 2007, 10:34:08 am »
I just went and looked at my grandfather's '79..I see what you mean about how it could be a common problem, I spend more time looking at 81-87 models, and the '79 obviously could trap a ton of junk in there and rust out.
Chris
