Author Topic: 79 clutch  (Read 3683 times)
Offline 75 C20
79 clutch
« on: October 17, 2007, 07:41:27 pm »
my 79 c20 350 with sm465 clutch was going out i thought- it was slipping pretty bad but then yesterday when i was drving i put my foot on the back side of the clutch pedal and lifted towards me- the clutch was not getting fully engaged. so now i can start off and as soon as i let the clutch out if i lift up it will fully engage and work fiine- is there any adjustment on this so it engages itsself completely or???
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Re: 79 clutch
« Reply #1 on: October 17, 2007, 08:26:58 pm »
The bushings are probably shot on the clutch/brake pedals.  IMO it was never a real good design when they changed it from the previous 72 and older.  The clutch pedal lever is spring loaded the opposite way.  My 85 has the hydraulic slave on it and you would swear it was not as much leg is needed to work it.  I would start at the bushings.  Make sure your z-bar under the hood is not binding and is greased.
Re: 79 clutch
« Reply #2 on: October 18, 2007, 09:22:20 am »
There is an adjustment on the mechanical linkage.  It is the rod that pushes on the clutch fork.  You need about 1-2" of play in the pedal to be correct.
