Author Topic: drivers door won't stay open and also has to be slammed to shut  (Read 9750 times)
Offline locdogg
« on: October 21, 2007, 07:56:22 am »
ok, sorry for all the newbie questions but you guys are tons of help.  A million thanks.
My drivers door won't stay open and also needs to be slammed in order to shut
It is constantly shutting on my leg while I'm trying to work on it.
Lately I have been wedging a screwdriver or whatever else I can find to keep it from shutting.
If I disassemble the door to clean and lubricate the latch do you think that will fix the need to slam it shut?
Do I need new hinges to keep it open?
Re: drivers door won't stay open and also has to be slammed to shut
« Reply #1 on: October 21, 2007, 11:07:51 am »
Check you stricker adjustment for the slamming.  Check the hinge stop/spring for it not staying open.
Offline okuma
« Reply #2 on: October 21, 2007, 11:02:07 pm »
you are probably missing the spring shaped like an "S" on your driver door...... check the passenger side where the hinges are and compare you will see where it should be..easy to replace....
also  when you replace to missing spring replace the door hinge bushings. your door probably does not close properly becase it is hanging--normal wear and tear!
try pushing your door up from the handle side... you will notice lots of play... ;)
« Reply #3 on: October 22, 2007, 06:56:32 am »
What okuma said. Also if you have been slamming it for a long time the damage might already be done to the latch. 9 times out of 10 when someone brings me this problem they should have brought it to me 6 months to a year before they did. the latch is always smashed up and junk from smashing it into the sticker at the wrong hight. I have even seen them where the latch is pushed outward in the door. The holes are egged out and the door sheet metal is all stretched toward the outside.
« Last Edit: October 22, 2007, 08:57:52 am by Blazin »
Offline locdogg
« Reply #4 on: October 22, 2007, 07:14:59 am »
thanks for all the info.  the latch and striker look ok although there is more wear on the very top of the striker.
also there is play in door, I did notice when I tried lifting it as okuma said
Offline okuma
« Reply #5 on: October 22, 2007, 07:30:05 pm »
LOCDOGG, then you only need to replace the hinge bushings <brass>. this will eliminate the play and lift the door sag. then replace the "S" pring to make this door stay open - when opened.... simple job ,but be carefull.
Offline 76_Scottsdale
  • I'd rather push my Chevy than drive a Ford
« Reply #6 on: October 23, 2007, 12:21:14 am »
not to take over this thread, but how do you adjust the striker/latch so that the door will shut more easily without slamming. Mine has all new strikers and seals the problem seems to be when you shut the door quickly the air has no where to go unless the windows are down.
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
True Dual 3" Flowmaster 40 Series Exhaust
« Reply #7 on: October 23, 2007, 06:50:16 am »
Its not the striker thats the problem, its the air tightness of the truck with new gaskets etc.
Offline mike357
« Reply #8 on: October 28, 2007, 06:05:37 pm »
will wore out hinges keep it from shutting right also?  i replaced the bushings and strikers on my '80 and it still is hard to shut. i dont have any movement in the doors when i rock them.i cant see that the latches are bent but i may try that next. when the door is shut the bottom of the door sticks out farther than the top.
« Reply #9 on: October 29, 2007, 06:49:18 am »
Sounds like it need to be adjusted to fit better. If the top is hitting the cab before the latch catches the striker it will not shut good.
