Author Topic: 1986 K10 3spd manual tranny issue  (Read 6806 times)
Offline Rascal407
« on: October 22, 2007, 04:40:41 pm »
Hi new poster here,
         My 1986 Chevy K10 305 4x4, 3spd manual w/ L recently developed a very noticeable shudder/jerking when I shift into 3rd? The engine idles and revs fine. Runs smooth in 1st and 2nd but the whole truck jerks/jumps when shifted into 3rd? If I rev high in 2nd and accelerate to 40-45mph then shift into 3rd, it is not as noticable but still present. Any ideas on what this could be?
             Thanks
                       Bob
Re: 1986 K10 3spd manual tranny issue
« Reply #1 on: October 22, 2007, 06:09:20 pm »
Sounds like a plug and or plug wire starting to go under load.  My $.02
Offline Rascal407
« Reply #2 on: October 23, 2007, 12:18:07 am »
I hope its that simple...
Offline DirtyLittleSecret
« Reply #3 on: October 23, 2007, 02:25:32 pm »
Ah, sounds familiar!
I had a rather similiar circumstance, but it was in 2nd gear rather than 3rd.  Oh, and mostly under load.  Noticed it immediately after I replaced the body mounts (what there was left of them).  It was the rear driveline falling apart, but didnt "feel" like a drive vibration.  $175 and I got a new drive with all new u-joints all around.  Now it rides like butta.
Just another thing to check...
78 K20: fresh 350, SM465, NP205, 4" Pro Comp, & working hard!
65 Jeep J300: 13.5:1 383, TH400, NP205, mostly NOS.
88 Toylet LandCruiser FJ62: LT1, 4L60e, 3" OME, Aussies.
06 VW TDi: DD@72mpg.
« Reply #4 on: October 23, 2007, 02:26:27 pm »
Could also be that your clutch got contaminated. :-\
Offline DnStClr
« Reply #5 on: October 27, 2007, 08:46:40 am »
Did you check the motor mounts? It sounds like a bad one.
Don
87 Chevy Silverado
Offline Rascal407
« Reply #6 on: October 27, 2007, 11:56:05 am »
Thanks for all the help. I believe its the wires. I was under the hood checking to make sure the wires werent contacting anything too hot and jiggled all the connections to the cap and plugs. Test drove it around the neighborhood and it ran fine. Drove it to work and it developed the same problem on the way back.
Offline Rascal407
« Reply #7 on: October 27, 2007, 11:58:31 am »
If I don't sell the truck this weekend, which I am not completely sure if I want to or not, I'll be replacing the plugs and wires shortly.
Offline Rascal407
« Reply #8 on: October 30, 2007, 06:43:16 pm »
...and the winner is......
zieg85
the air tube/pump on the passenger side corroded away, leaving one rusted nut in the manifold, about 2 months ago,I got the bolt out after alot of wd40 soaking and eventual torching and drilling, replaced the air pump/tube. the plug wires were attached to the old tube, i never reattached them to the new tube. One of the wires was resting too close to the manifold.
« Last Edit: October 30, 2007, 10:10:59 pm by Captkaos »
