Author Topic: Factory mechanical sending availibility  (Read 5673 times)
Offline 77c15
  • combustion=suck, squeeze, bang, blow
    • My cardomain site...
« on: November 06, 2007, 06:04:25 pm »
Speaking of mechanical oil pressure sending units, anyone know where you can buy one? I looked through all of our catalogs at AutoZone, searched through all the sending units at Advance, and   doesn't list one. I am lost. My 74 has the brass looking tube from the firewall to the block.
« Last Edit: November 06, 2007, 06:25:17 pm by Captkaos »
Offline baddogg79
Re: Factory mechanical sending availibility
« Reply #1 on: November 06, 2007, 08:27:17 pm »
I thought there was no sending unit for the mech oil pressure gauge. Just the metal tube to the back of the gauge itself ???
Offline DnStClr
« Reply #2 on: November 07, 2007, 01:56:43 am »
That's right. There's no sending unit on a mechanical oil pressure indicating system.The oil flows right to the gauge and the gauge is made so it can react to the pressure of the oil.
Don
87 Chevy Silverado
« Reply #3 on: November 07, 2007, 09:47:25 am »
Sorry for no replying when I split this.  Mechanical oil pressure units don't have a sender as stated above, they plug directly into the block and oil travels to the gauge.  (don't loose the ferels on these, they are GM specific and I haven't found them)
Offline 77c15
« Reply #4 on: November 07, 2007, 07:00:34 pm »
That's what got me: I lost the ferels when I ditched the 307 that was rigged up in the truck when I bought it and must've left them attached to it. I've got some brass connectors rigged up for now, so I guess as long as they don't leak (sealed with teflon tape), then I should be good to go. Thanks, Chris!
« Reply #5 on: November 07, 2007, 10:36:24 pm »
If they don't leak you got it made.
