The Highs (Raising/Lifts)
lift suspension
Topic: lift suspension (Read 7596 times)
gpday08
lift suspension
November 08, 2007, 04:12:42 pm »
I cant find any lift kits for my '79 C10!!! any help please?? im thinking 3" (only if needed) body, and about 4"-6" suspension with about 35" tires
Re: lift suspension
November 08, 2007, 05:14:43 pm »
If you are actually talking about a C10 (2WD) there is only a few that makes a lift for it.
http://www.fabtechmotorsports.com/applications/gm/2wd73-98c1500.html
It is only 3" and will only clear 33x10.50 after trimming.
http://airbagit.com/product_info.php?products_id=7937&osCsid=add81a6504c950e2dca495cbab859fe8
http://airbagit.com/product_info.php?products_id=7938&osCsid=add81a6504c950e2dca495cbab859fe8
http://airbagit.com/product_info.php?products_id=8250&osCsid=add81a6504c950e2dca495cbab859fe8
gpday08
Re: lift suspension
November 09, 2007, 01:33:08 pm »
well i want at least 4", is there anyway to modify any one of these 4" setups? so that i can get my truck, which uses coil springs up front to accept one of these kits?
http://www.suspensionconnection.com/cgi-bin/suscon/147104.html
werewolfx13
Site Supporters
Re: lift suspension
November 09, 2007, 01:36:22 pm »
I'm just curious..why do you want to add that much lift to a 2wd truck?
Chris
'83 Chevy c10 Silverado SWB
okuma
Re: lift suspension
November 09, 2007, 03:54:26 pm »
search Ebay......you will find
it
gpday08
Re: lift suspension
November 09, 2007, 04:00:04 pm »
its more for looks than anything! because im planning on picking up a newer truck, like a 2007 1500ss in a while and that will be my sport truck as where this will be my worker
Rockin77
Re: lift suspension
November 10, 2007, 01:25:56 am »
id like to do the same thing but with a 3/4 ton c25 gmc. I want to put 35s on i already have 33s with stock suspension.
Last Edit: November 11, 2007, 12:43:09 pm by Rockin77
1977 GMC High Sierra 25
Re: lift suspension
November 10, 2007, 10:11:02 am »
There is no way to modify a 2wd to use leafs up front short of buying a 4x4.
lift suspension
