Author Topic: Need some body suggestions!!!  (Read 43646 times)
Offline nova801428
Re: Need some body suggestions!!!
« Reply #30 on: November 18, 2007, 11:28:52 pm »
Yes...but with me....screwing up = $$$
1975 Chevy k20 6" lift 35" BFG MT's True Dual Exhausts Radical Cam
1980 GMC 2500 Parts Truck
Offline nova801428
« Reply #31 on: November 21, 2007, 10:50:44 pm »
O.K.  It turns out I want to just replace the front clip and floor boards right now until I get enough money and time (also a garage) to completely restore it.  So, what all will I need?  I am not sure if I need the whole cab kit or not.  I forgot, but do they cover both sides of the floor (ex. driver and pass. side)?
 Thanks
Offline loudnlow87
« Reply #32 on: November 22, 2007, 06:55:16 pm »
how do you figure that front end is wrecked?
and def just fix the rust dont swap cabs.
stock really sucks
« Reply #33 on: November 23, 2007, 04:18:33 pm »
Our pieces are per side.  Left = Drivers, Right = passenger.
Offline nova801428
« Reply #34 on: November 23, 2007, 06:28:39 pm »
Kind of confused as to what I need to get.  I will take some pics and let you decide what I need.
 Thanks
« Reply #35 on: November 23, 2007, 06:46:26 pm »
No problem.  It is going to be hit/miss over the Holiday weekend for visiting the site, but I will respond when I see it.
Offline nova801428
« Reply #36 on: November 23, 2007, 06:46:43 pm »
Both driver and passenger side floor boards need to be replaced.  But, the question is, do I need the whole cab kit?  I don't think I need the cab corners but I will let you decide.  Thanks
Driver side...not too bad.
Passenger side....ewww
Passenger side fender
« Reply #37 on: November 24, 2007, 07:20:21 am »
If I were to look at this as a job, I would tell the customer you need cab corners, rockers, inner rockers, floor pan, possibly inner cab corners, or some sort of patch & possibly floor support.
Once you cut into it I would bet $ it will need everything.
 I think you will find that your cab corners have already been done once.
Offline loudnlow87
« Reply #38 on: November 24, 2007, 01:17:05 pm »
Quote from: Blazin link=topic=6474.msg35106#msg35106 date=1195910421
[/quote
yea those pinch welds look pretty messy to be factory, even for GM haha.
stock really sucks
Offline nova801428
« Reply #39 on: November 24, 2007, 05:49:30 pm »
So, you think I need rockers for both sides?  The driver side looks fine to me, only looks like surface rust.  Anyway.  So, I pretty much need the cab kit (left and right) from this site?  Thanks
Offline Fordeatinz71
  • 78k miles and counting
« Reply #40 on: November 24, 2007, 07:10:24 pm »
yea man, you need to get everything for both sides.  that truck has been repaired before and it really doesn't look to have been done right...you need to find someone who is good at welding in new panels and have it done right...
Offline nova801428
« Reply #41 on: November 24, 2007, 09:42:37 pm »
My step dad does excellent welds.  So, this sounds like a project.  I don't think I am going to restore the truck though.  I am going to just fix whats wrong with it for now.  I want to restore a shortbed 2wd truck rather than my lifted 4wd.  Thanks for the help....I will probably doing this again in the future.  This sounds like a Christmas Present to me!!!  ;D ;D ;D
Offline loudnlow87
« Reply #42 on: November 25, 2007, 01:46:30 am »
keep in mind you dont have to weld the patches in. they have body glues out now that are literally stronger than welds. ive known people that installed rust patch panels with it, and theyre safe to use even on quarters and things like that, so for a cab corner, it should be fine. just something to consider.
stock really sucks
Offline nova801428
« Reply #43 on: November 25, 2007, 02:57:32 am »
Really?  Where do you find it and how much is it?  Is it easy to use?
 Thanks
« Reply #44 on: November 25, 2007, 10:20:31 pm »
Fusor is the brand I use. You have to by a special calking type gun to use their two part tubes. The gun is around $80.00
