Author Topic: T-10 4-speed  (Read 6892 times)
Offline got2haul
T-10 4-speed
« on: November 15, 2007, 09:53:49 am »
Anyone running one of these Richmond Gear T-10 4-speed transmissions?  I'm looking for fitment comments.
1980 Custom Deluxe Stepside
        Stepside thread: http://forum.73-87chevytrucks.com/smforum/index.php?topic=7505.0
1976 GMC Sierra Grande C15
Re: T-10 4-speed
« Reply #1 on: November 15, 2007, 11:08:59 am »
It should fit fine.  It is basically the same as a muncie 3 or 4 speed.  I used a M22 passenger car Muncie for 7 years.  I have a Nash 4+1 that replaced it now. (Richmond bought Nash tooling)
Offline got2haul
Re: T-10 4-speed
« Reply #2 on: November 15, 2007, 12:34:20 pm »
So tell me about the Nash 4+1.  What's the "+1", overdrive or 5th?  So you're saying I probably won't have to modify the cross member?  I currently have the OEM 4-speed with granny low.
Re: T-10 4-speed
« Reply #3 on: November 15, 2007, 01:32:26 pm »
Nash 4+1 is identical to the Richmond  5 speed.  No overdrive.  5th is 1:1.  I didn't want overdrive.
You have the toploader SM465 then.  It will fit with no problems, just bolt it in and go.  The biggest hurdle is cutting a new hole in the floor.
Offline sav_x69
Re: T-10 4-speed
« Reply #4 on: December 15, 2007, 01:35:11 pm »
does gm have any manual od trannies
Re: T-10 4-speed
« Reply #5 on: December 15, 2007, 02:47:14 pm »
MY 6 is a 4 speed overdrive.  OD being the 4th. gear at .71  It is the same size as a muncie, and made for our trucks.  I have 3 of them...
Offline sav_x69
Re: T-10 4-speed
« Reply #6 on: December 15, 2007, 03:15:32 pm »
do they make them for 4x4
Re: T-10 4-speed
« Reply #7 on: December 15, 2007, 05:38:37 pm »
mm 7 was the RPO for a 4x4.  They are vary rare and I have only seen 1.  3.09 first gear with a .71 final.  It is a New Process A-833.  It is the GM cased Mopar A-833.  The non-overdrive version was the hemi 4 speed.  Looks like I will be putting one in my C-10 soon replacing the 3 speed.  I have one for the Chevelle as well.  I haven't actually driven one in a truck but I have the Mopar version and the gears are long but managable.
Re: T-10 4-speed
« Reply #8 on: December 15, 2007, 07:14:40 pm »
The A-833, in just an ancestor of the Hemi 4 speed, they don't have the same strength.  They are known for being VERY weak behind mildly built 350's.  They came behind light duty diesels mostly and were offered in 1981..  It wasn't available behind BBC's or HD diesels.
Offline the dan
Re: T-10 4-speed
« Reply #9 on: December 21, 2007, 10:26:29 am »
i had a th350, and bolted a muncie m20 up with a tranny mount out of a 78 camaro (not sure if that ment anything),
Re: T-10 4-speed
« Reply #10 on: December 22, 2007, 09:58:04 pm »
Check out auction #150197348157 on E-bay
