Author Topic: rearend gearing  (Read 4822 times)
Offline the_legend_1981
rearend gearing
« on: November 17, 2007, 11:30:41 am »
how can i figure it out with no tags or anything?
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: rearend gearing
« Reply #1 on: November 17, 2007, 11:48:00 am »
Take the rear cover off.  Count the ring gear teeth.  Count the pinion gear teeth.  Divide the two numbers. You should come up with 2.73, 3.08, 3.73, 4.10 or something similar.
Re: rearend gearing
« Reply #2 on: November 17, 2007, 12:11:52 pm »
If you spin the ring gear over the numbers will be stamped on it so you don't have to count them...
Offline Fordeatinz71
  • 78k miles and counting
Re: rearend gearing
« Reply #3 on: November 17, 2007, 04:53:24 pm »
or, if you don't wanna take off the diff cover, you can use this method which will get you close enough to figure it out...
1. put a mark on the pinion yoke, and one on the axle housing (use something visible from a distance)
2. now put some sort of mark on the tire and something on the body (if you think you can remember the exact point, do that, if not, use some tape or something...)
3. jack the rear end of the truck up and secure it on jackstands, chock front wheels.
4. put truck in neutral and, while looking at the pinion (you should be able to see it through the wheel well if you get at the right angle...if not, then change your marks to the inside of the tire and an inside reference point on the truck) slowly rotate the tire while looking at the driveshaft...pay attention to your tire as well, when it rotates around once, you should have counted a few rotations of your driveshaft...here's an example...tire was rotated one full revolution, driveshaft spun around ALMOST 4 times...you probably have 3.73 gears.  get where i'm going with this?
Offline sav_x69
Re: rearend gearing
« Reply #4 on: December 17, 2007, 06:29:44 pm »
anyone everherd of 3.41 gears there out of my 83 4x4 and how good are they?
Re: rearend gearing
« Reply #5 on: December 18, 2007, 09:41:55 am »
how good are the gears or how good are they for use?  They are fine.  They are actually 3.42 gears..
Re: rearend gearing
« Reply #6 on: December 18, 2007, 09:14:02 pm »
wow, i wish i'd have had 3.42's from the factory!  my truck might be able to get out of her own way!
