Author Topic: 87 P30 Motorhome 7.4L Timing Gear-Steel or Nylon?  (Read 4677 times)
Offline bberger
« on: November 19, 2007, 11:14:19 am »
I have a 1987 P30 Motorhome with a 454. I have about 120,000 miles on it and I am concerned about the timing chain & gears. It runs like a top but I am worried that the timing gear being ready to puck. How can I find out if it is a steel or nylon gear. Just because it is a 1987 motorhome doesn't mean it is a 87 engine. It could be a 1986!
Re: 87 P30 Motorhome 7.4L Timing Gear-Steel or Nylon?
« Reply #1 on: November 19, 2007, 11:45:05 am »
It is probably nylon if it is factory. Is it TBI or carb'd.
If it is carb'd and you can afford to pull it apart to replace it, I would.  I wouldn't trust a nylon gear much over 100,000 miles.
If it is TBI it probably has a metal gear, but it wouldn't hurt to check.  Have you seen any chunks in the pan when changing the oil.
Offline bberger
« Reply #2 on: November 19, 2007, 12:49:29 pm »
It's got a carb and the oil is clean. It's not the expense it's the way I have to change it. I have to do it from the bottom on my back with my feet to the back of the motorhome. It should be a real pain but doable. That's why I am trying to find out what it is!
« Last Edit: November 19, 2007, 01:06:06 pm by bberger »
