Author Topic: Homemade Headers  (Read 188451 times)
Re: Homemade Headers
« Reply #15 on: December 12, 2007, 11:18:48 am »
If the one on there is choking it, are you going to make a less restrictive Air intake?
Offline 123 pugsy
« Reply #16 on: December 12, 2007, 01:40:50 pm »
I've already got a nice big K&N air filter that fits the 4" tube I have set up. Pretty much plug and play, just needs a bracket to hold up the end of it. It comes with a 1/4-20 thread stud.
Pugsy
76 C10 LWB
TPI 350
« Reply #17 on: December 12, 2007, 02:56:59 pm »
That would do it!
Offline 123 pugsy
« Reply #18 on: December 15, 2007, 05:10:50 pm »
OK, now is about the 5th go at it but I think I've got one side about done with every primary within 1" of each other.  :) They will be 32"  with ???" long collectors. Gotta research optimal collector length for this low HP, higher torque engine.
Pugsy
76 C10 LWB
TPI 350
Offline jonkmbll89
« Reply #19 on: December 15, 2007, 08:29:25 pm »
They will be one of a kind.
Offline 87GMC2WD
« Reply #20 on: December 16, 2007, 09:01:48 am »
that looks awesome. lots of props to you
Offline the dan
« Reply #21 on: December 17, 2007, 02:14:18 pm »
awsome job
« Reply #22 on: December 17, 2007, 02:28:08 pm »
Well after the disappointing DYNO results ,I decided to build some stainless steel headers. I got some flanges waterjet cut out of 3/8 s/s plate and some 1-1/2" s/s elbows.
123... You wouldn't have any extra flanges for sale??  I need a set to space my exhaust manifold out about 3/8" out on the drivers side so I can retain the original exhaust manifolds for use on an older block with the dipstick tube on the drivers side.  PM me, I don't want to hijack the thread.
Offline team39763
« Reply #23 on: December 17, 2007, 02:54:10 pm »
Nice work 123Pugsy. Those are looking good.
Offline 123 pugsy
« Reply #24 on: December 17, 2007, 04:37:28 pm »
[/quote]
Hijack away. We're here to shoot the breeze.
 What I have is an Autocad drawing that any waterjet shop could use to cut them.
If your manifold just has that cast iron between the flanges that's interfering,that could  just be cut off.
Pugsy
76 C10 LWB
TPI 350
Offline 123 pugsy
« Reply #25 on: December 17, 2007, 04:42:57 pm »
awsome job
Thanks guys.
Its not like I'm gonna have rip roarin power or anything , but I've installed headers before and not notice a difference. I hope these "feel" like they give me a bit.
The Dyno will tell.....
Pugsy
76 C10 LWB
TPI 350
« Reply #26 on: December 17, 2007, 05:48:27 pm »
That is not the problem, The manifold off a 86 is the problem. The dipstick tube was straightened out to go behind the manifold but is smashed now because the clearance is about 1/2 the thickness of the dipstick tube...
[/quote]
« Last Edit: December 17, 2007, 06:15:57 pm by zieg85 »
Offline 123 pugsy
« Reply #27 on: December 17, 2007, 06:40:46 pm »
You got a pic of the problem? There must be an easy fix for your problem.
Pugsy
76 C10 LWB
TPI 350
« Reply #28 on: December 17, 2007, 07:13:34 pm »
As you can see if I had some spacers I could use this exhaust manifold.  No other way around it that I can see shy of going with the older style exhaust manifolds which would require a new y pipe.  I have to retain the exhaust for emission tests.
Offline 123 pugsy
« Reply #29 on: December 17, 2007, 07:57:03 pm »
Looks like you should just use the older style. It looks like it dumps in the same spot.
Pugsy
76 C10 LWB
TPI 350
