Author Topic: Homemade Headers  (Read 188478 times)
Offline jonkmbll89
Re: Homemade Headers
« Reply #45 on: December 22, 2007, 06:41:38 pm »
Thanks.
Its going so slowwwwwwww. :P
The last set I did was quicker as all I was concerned about was clearing the frame and not the tube lenghts.
Pugsy, you do good work. :o
Offline 123 pugsy
« Reply #46 on: December 22, 2007, 08:36:07 pm »
Thanks. I should have pics tommorow of 1 side pretty much done. I don't know how its going in though, may have to lift the motor.... :P
Pugsy
76 C10 LWB
TPI 350
Offline 123 pugsy
« Reply #47 on: December 23, 2007, 05:45:38 pm »
Got the collector cut and welded to the header.
I just got to check the fit now and then finish welding the tubes to the flanges.
Pugsy
76 C10 LWB
TPI 350
Offline 123 pugsy
« Reply #48 on: December 23, 2007, 05:46:58 pm »
A couple more pics.
Pugsy
76 C10 LWB
TPI 350
Offline JJSZABO
« Reply #49 on: December 23, 2007, 06:53:38 pm »
WOW - I can't say enough - WOW.  Great work.
Thanks for the pictures pugsy and vile.  I am thinking of making an engine stand, when I am done with this truck.
Jeff
86 Chevy C-10
350, TH400
Offline jonkmbll89
« Reply #50 on: December 23, 2007, 06:57:17 pm »
I don't care what anybody says, that is fine work. ;D
« Last Edit: December 24, 2007, 06:06:16 pm by jonkmbll89 »
« Reply #51 on: December 24, 2007, 08:34:27 am »
Pugsy, are you going to run your wires forward and then along the valve cover? Looks great! Very unique!
Offline 87GMC2WD
« Reply #52 on: December 24, 2007, 08:41:17 am »
amazing, ive fabricated snowblower holders and all sorts of trailers and home-made pullers, but i dont think i could ever do this. Dont know if id have the pateince.
Offline 123 pugsy
« Reply #53 on: December 24, 2007, 09:24:53 am »
I don't care what anybody says, that is dam fine work. ;D
Thanks guys. I still have to find the patience to finish the other side along with 1 more exhaust pipe as well. :o
Pugsy
76 C10 LWB
TPI 350
Offline 123 pugsy
« Reply #54 on: December 24, 2007, 09:29:44 am »
Thanks for the reminder. I've got to figure out the wires before ceramic coating. I may weld tabs to screw wire holders to if needed to keep them away.
Pugsy
76 C10 LWB
TPI 350
Offline 123 pugsy
« Reply #55 on: December 28, 2007, 09:42:42 am »
I ground down an 18mm s/s nut with a zipcut disc to use as an o2 sensor bung.
Pugsy
76 C10 LWB
TPI 350
Offline 123 pugsy
« Reply #56 on: December 28, 2007, 09:48:27 am »
Round peg in a square hole. I had to stretch the corners out with a hammer and punch.
Pugsy
76 C10 LWB
TPI 350
« Reply #57 on: December 28, 2007, 11:11:05 am »
Very cool Pugsy!
Offline ccz145a
« Reply #58 on: December 28, 2007, 11:31:52 am »
Nice work!
Offline jonkmbll89
« Reply #59 on: December 28, 2007, 06:15:52 pm »
Nice job.
