Author Topic: rebuilding door hinge questions  (Read 8160 times)
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« on: December 13, 2007, 12:53:57 pm »
I rebuilt my door hinges on my 84 gmc I'm restoring but the new pins wont go down the last 1/8" or so how do you get them down all the way? Thanks
Offline 82chevy
Re: rebuilding door hinge questions
« Reply #1 on: December 13, 2007, 06:55:27 pm »
just pound on it really hard haha
Offline JJSZABO
« Reply #2 on: December 14, 2007, 08:26:07 am »
When I did mine I had to use a large hammer and pound the snot out if the pin to get it to seat.  The grooves will catch then thats when you start pounding.  Mount the hinge body in a good heavy vise a start hammering.  Not fun :(
Jeff
86 Chevy C-10
350, TH400
« Reply #3 on: December 14, 2007, 10:08:08 am »
I used a brass punch and knocked it down...
Offline 78BBSTEPSIDE
« Reply #4 on: December 14, 2007, 10:23:36 pm »
I would suggest a press. If you do not have access to one, any machine shop can handle the task.
« Reply #5 on: December 15, 2007, 07:51:09 pm »
you don't need a press for door pins, I have they aren't a major interference fit.  I have installed them with the doors on the truck several times.
Offline alex
« Reply #6 on: December 21, 2007, 07:20:29 am »
best way to door pins in and out is an air hammer with a cupped riveting tool....same tool we use for changing wheel studs .....
Offline 123 pugsy
« Reply #7 on: December 22, 2007, 05:57:30 pm »
Or you could rebuild them and never worry about them again. I drilled the inner part to 1/2" and welded a pce of 1/2" tube with a zerk fitting. The outer ,I drilled to 3/8 and welded a 3/8" solid bar. They'll never come apart , but they have absolutely zero play.
Pugsy
76 C10 LWB
TPI 350
