Author Topic: blew up the rear...  (Read 4699 times)
Offline loudnlow87
blew up the rear...
« on: December 14, 2007, 10:35:22 am »
had to get towed home last night after destroying 2 spider gears, breaking a pinion tooth, chipping a pinion tooth, and massively gouging the spider carrier housing.
im probably going to find a used axle from a salvage yard, leery about rebuilding with this housing because of the stress it probably has. have to get this back on the road ASAP its all i got.
while im going through all this work, might as well make it better if i can. will a 12 bolt swap right in?
stock really sucks
Re: blew up the rear...
« Reply #1 on: December 14, 2007, 12:58:18 pm »
12bolt will swap in, but you aren't gaining anything other than a bigger diameter ring gear, the pinion shaft is smaller than a 10bolt.
Offline loudnlow87
« Reply #2 on: December 14, 2007, 01:08:50 pm »
ok thanks. just got off the phone with the salvage yard, they have them in stock, possibly one with factory posi, gonna pick one up tomorrow morning...about $250, + losing a day's work.
stock really sucks
Offline 1976Scottsdale
« Reply #3 on: December 14, 2007, 03:12:51 pm »
Also gonna need a different rear u-joint since the yokes are different.  Someone told me that the 12 bolt uses a 1310 u-joint and the 10 bolt uses a 1350 u-joint?  Not sure about that part but I know for a fact that the yokes are not the same in terms of u-joint size from when we swapped 1- bolts into my dad's 79 K-10.
Offline loudnlow87
« Reply #4 on: December 16, 2007, 09:28:53 am »
stock really sucks
Offline Fordeatinz71
  • 78k miles and counting
« Reply #5 on: December 16, 2007, 12:55:54 pm »
one word...OUCH!
Offline 85MudMonster
« Reply #6 on: December 16, 2007, 01:22:26 pm »
wow!!  :o
Dan
85 Chevy K10 - 408 BBC from a 71 Chevelle SS, TH350, NP208, 33" Mastercraft Courser M/T
