Author Topic: Leaf spring removal  (Read 7228 times)
Offline qboy
Leaf spring removal
« on: December 16, 2007, 05:07:35 pm »
I've got 6 leaf springs on each side in the back of my 75 GMC 1/2 ton SBC 4x4.   I want to remove two on each side.   Which two should I remove?
1975 K15 GMC 1/2 ton SWB 4x4 383 (stroked 350), turbo 350 tranny
Offline jonkmbll89
Re: Leaf spring removal
« Reply #1 on: December 16, 2007, 05:41:08 pm »
Why do you want remove leafs?
Offline 123 pugsy
« Reply #2 on: December 16, 2007, 07:29:31 pm »
The 2 shortest ones.
Pugsy
76 C10 LWB
TPI 350
Offline qboy
« Reply #3 on: December 16, 2007, 09:36:50 pm »
The rear is stiff and I never carry much of anything.
Offline 123 pugsy
« Reply #4 on: December 17, 2007, 05:28:10 am »
You do understand that it will drop about 1-1/2 - 2" when you take out the springs,right? :o
Pugsy
76 C10 LWB
TPI 350
Offline qboy
« Reply #5 on: December 17, 2007, 07:17:41 pm »
Yeah.   That's ok.   I've heard different stories as far as which ones to take out.  Such as "take one, leave one, take one leave one".
Offline jonkmbll89
« Reply #6 on: December 17, 2007, 07:35:36 pm »
My dad has a 1990 454SS. He took out one and it leveled out the truck.
Offline qboy
« Reply #7 on: December 23, 2007, 09:23:49 pm »
I've got 6 leafs in the back.    A mechanic told me to just remove the third one from the top and that should be enough to soften it up.
« Reply #8 on: December 24, 2007, 04:47:48 pm »
Don't remove the upper springs, remove the lower/shorter ones.
Offline qboy
« Reply #9 on: December 26, 2007, 10:54:10 pm »
Well, it done.   Took out the 2nd front the top and the 2nd from the bottom.   Also, put on new Rancho shocks.    Tested it out tonight.   It drives real nice now.    Night and day difference from how it used to be.
