Author Topic: 83 c10 re-innovated Pro Touring  (Read 516815 times)
Offline the dan
Re: 83 c10 re-innovated, air ride
« Reply #300 on: February 16, 2012, 11:20:22 pm »
passenger firewall is done and seam sealed around the inside... driver side is being a PITA with that  pedal box, but ill make it work, gotta cut the box down about in inch, trying to get as much leg room as possible.
« Reply #301 on: February 17, 2012, 10:25:41 pm »
I like it! Great job!
Offline the dan
« Reply #302 on: February 20, 2012, 11:27:43 pm »
Tonight i ordered an Ididit tilt steering column, and cut all but a half inch off the pedal box, and i dropped the driver floor down 3" so the pedals could move forward. it wasnt perfectly comfortable when i was sitting in it so i figured do it now instead of regreting it later...
Offline the dan
« Reply #303 on: February 26, 2012, 11:58:33 pm »
Got the upper A arms tacked into location with extra tubing to notch, and tested how far the suspension travel is. and it will drop to the ground stuffing the 20's on corvette c5 suspension. pretty pumped about that.
also finished the center section to my firewall had it all laser cut at work/ as well as redesign and welded in the pedal box
then got a roll on the engine cover since the center section of the firewall will be tigwelded to the engine cover i wanted to prove everything out before i started at it
« Last Edit: February 27, 2012, 05:08:15 pm by the dan »
Offline 87454westernhauler
« Reply #304 on: February 27, 2012, 10:05:07 pm »
that looks pretty sweet
79 gmc c20 350 th350
78 k1500 4x4 350 th350
« Reply #305 on: February 27, 2012, 11:12:45 pm »
Nice progress!
Offline the dan
« Reply #306 on: February 28, 2012, 12:12:21 am »
hey thanks, got alot of work coming in on it in the next couple weeks, cage should be complete by the end of march, which means it can come off the chassis jig and roll on all 4's
Offline the dan
« Reply #307 on: March 15, 2012, 12:07:58 am »
gonna need a couple front fenders or beds to make some fender raisers because my wheel wells are too low, Vile i dont know if you have any but i can get them out of your yard for a couple $
« Reply #308 on: March 17, 2012, 09:26:37 am »
Are you going with the 73-80 front end or 81- up? I have plenty of 73-80 fenders.
Offline 1979C20
  • Kyle Taulton.
« Reply #309 on: March 17, 2012, 12:05:09 pm »
Your truck looks awesome, and I wish I had the time and money to make build my truck even half as good as yours. Crazy attention to detail.
Offline the dan
« Reply #310 on: March 25, 2012, 11:51:26 pm »
been doing alot of customer car work but that just means more income for the c10
Tonight i tackled one of the hardest things ive had to do yet, and thats make a contoured cut in a blind area, it came out fantastic and do not think i could ever do it so nice again if i had to.
thats the picture inside the cowl
oh and i forgot to mention i had to pull the cab off and shorten the frame 1.5" because the truck isnt factory wheel base anymore for some reason... the front wheel was off center 3"... so the motor is back 1.5" more now so i had to remake the engine tunnel wider and also made it higher for the future fuel rails, 3" higher
more to come of coarse.
Offline the dan
« Reply #311 on: March 25, 2012, 11:52:37 pm »
oh yeah, i also finished the lowering the angle of the drivers floor board, 1.5" and rewelded it in with a new filler piece, no pics
« Reply #312 on: March 26, 2012, 12:26:06 am »
Looks awesome!
Offline the dan
« Reply #313 on: April 22, 2012, 11:57:42 pm »
got my transmission tunnel mocked up with cardboard (i ended up cutting it all out of 18g on friday)
started the front part of the cage and into the cab
and mock up of some of the bends
[IMG]http://i44.tinypic.com/1h4b5c.jpg
« Reply #314 on: April 23, 2012, 07:48:04 pm »
Looks good. Are you going with the 73-80 or 81-87 nose?
