Author Topic: how much of dynamat needed?  (Read 9104 times)
Offline okuma
« on: December 25, 2007, 10:28:48 pm »
as the topic says: how much of dynamat or brownbread is needed for a single cab?  i want to do the roof also. under the headliner...
i see the 27sqf  50sqf  100sqf..   which do i need for entire truck?
Offline baggedk5
Re: how much of dynamat needed?
« Reply #1 on: December 26, 2007, 02:38:37 am »
I think I bought a 100sq ft. to do my blazer. I put it down, front to back, side to side, also up the bed sides, under the dash and door panels...had ust enough left to do the doors on another truck.
 but, that was a blazer...i dont see why 50sq ft shouldnt be enough
I reject your reality, and substitue it with my own!
Offline werewolfx13
« Reply #2 on: December 26, 2007, 03:41:38 am »
Depends on how many layers you want..one layer helps a lot, but most areas I prefer 2-3 layers..i'd go for atleast 50 sq ft, if not 100..100 will give you plenty for mistakes, double layering the floorboards up to the firewall, and smaller future projects.
Chris
'83 Chevy c10 Silverado SWB
Offline baggedk5
« Reply #3 on: December 26, 2007, 11:32:14 am »
buy the non big brand name stuff on ebay. I dont remember which company makes it, but one of them is very close to the same a "dynamat"
« Reply #4 on: December 26, 2007, 12:45:46 pm »
Jeff did this recently on his truck.  He used 70 sq ft.  Check here: http://73-87.com/7387garage/interior/sound_deadening.htm
Offline okuma
« Reply #5 on: December 26, 2007, 07:44:23 pm »
do you have any idea which one was it there are tons out there.
Offline werewolfx13
« Reply #6 on: December 27, 2007, 12:34:48 am »
Most of them work the same, Brown Bread is good and fairly cheap. E-dead is also good and reasonably cheap, AND comes in a liquid form as well. I like using a liquid deadener on the entire interior of the cab, then one layer of mat on some of the less guilty panels, two layers on the floorboards and firewall.
Chris
