Author Topic: welding question  (Read 6464 times)
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
welding question
« on: December 29, 2007, 04:14:23 pm »
can you use a extension cord on a 120v mig? Goofy me I have my project truck on the side of the garage with no outlets. I've been practice welding on a scrap hood and I think I have it down enough to start my floors, cab corners, and rockers on my 84 gmc. Thanks
« Last Edit: December 29, 2007, 04:31:22 pm by dumbucket1 »
Offline Redneckchevy
    • Photo Bucket
Re: welding question
« Reply #1 on: December 29, 2007, 05:55:41 pm »
Sure you can....Just dont go over bored with  one that is longer then u need....Make sure its a dedicated circuit and the cord is of heavy gage i do it all the time..
« Reply #2 on: December 30, 2007, 11:10:49 am »
If it welds crappy or trips the breaker you know you will need a heavier cord.
Offline werewolfx13
« Reply #3 on: December 30, 2007, 02:10:17 pm »
I've got some good cable I use for running my air compressor, its 50 amp 120v RV cord, 10/3 w/o ground, VERY flexible..if you can find it, thats the good stuff. It usually runs about $4.50-6.50/foot at a retailer though. A normal 12 ga extension cord no longer than 50 feet should be fine though..I ran a little 70 amp stick welder on one for one repair.
Chris
'83 Chevy c10 Silverado SWB
Offline Bitzer!
  • Smiles per gallon
« Reply #4 on: January 05, 2008, 01:43:05 pm »
like the other guys say- quality cable counts. Just make sure that if its on a reel make sure its unwound so it can "breathe" and not get too hot and melt together. I can assure you it can happen!!
1979 GMC CrewCab  C20 1t
Offline werewolfx13
« Reply #5 on: January 05, 2008, 06:41:39 pm »
Yeah, that can happen if you use a normal extension cord. Any 120v piece of equipment won't melt the jacket of that 10/3 RV cord even tightly wound..Your house wiring, outlet, and breaker would overheat LONG before the insulation of that cable will even get lukewarm to the touch. The one problem did occur to me a couple days after mentioning it in the first place..its REALLY bulky and heavy..the outter jacket is about 1" diameter, and it coils like a big garden hose, but weighs a lot more.
Chris
